LinkBack | Thread Tools | Display Modes |
#17 (permalink) |
Hello Bryan,
In the maximiser ckt. the 0.1 microF capacitir (which is connected to the FET) is also connected to both the terminals of 1.5K! There could be something wrong in my statement or could be in the image. Could you go theugh it and confirm where exactly the Cpacitor terminal is connected? Warm regards, Amitraj |
#18 (permalink) |
Hello All,
I have come up with "probable" corrections in the ckt. Diagram given for the maximiser at : http://www.voltscommissar.net/minimax/minimax.htm 1. Acc/to the diagram the 2K trimpot is connected to the junction where 3K3, 6.2V Zener, 100K, 100pF and Pin 2 of LM311N come together. In this case the 3K3 and 6.2V Zener junction should be separated. That means there should be a jumper which will connect Pin2, 100K and 100pF to 2K trimpot and will cutoff 3K3 and 6.2V connection. (I hope this makes clear what I want to say!!) Otherwise, pins 2 and 3 of LM311N will be shorted. 2. Same applies to o.1microF and 1.5K connect. If 0.1 F is also connected to Pin7 of LM311N then 1.5K gets shorted.Please let me know if I have gone wrong somewhere. Or I am getting overconfident about this. Warm regards, Amitraj |
#19 (permalink) |
3
Pin 8 and 7 are shorted through 100pF and 100K. jumpers are required at both the junction point. i. "100pf and pin 8" & "100K & pin 8" Please correct if anything faulty here. |
#20 (permalink) |
Experienced Member
Hiya amitraj,
Below i've ammended the schematic to show you where some lines cross they aren't connected. It is an error on schematic as usually a small raduis is put onthe line to show no connection. revised max circuit.jpg Cheers Bryan
" The only way to avoid human error is to avoid the use of humans" |
#21 (permalink) |
Experienced Member
No Bryan,
You have both inputs of the comparator shorted together. The (-) input connects to the 3.3k resistor and the 6.2V zener diode. The (+) input connects to the slider of the 2k trimpot, the 100k resistor and the 100pF capacitor. At the output you have two zener diodes shorted together. One is used to limit the gate voltage to 15V and the other limits the supply (bottom of the 470 ohm resistors) when the supply is 24V. The 0.1uF capacitor near the output should not connect to the gate of the Mosfet. It connects to the supply. I think you have pin 8 of the comparator shorting the 1.5k load resistor. EDIT: Sorry Bryan, I read your fine print. Your dots are not connections. Usually dots are connections.
Uncle $crooge Last edited by audioguru; 5th April 2008 at 12:34 AM. |
#22 (permalink) |
Great!!!
I have also reached to the same diagram... Bryan and Audioguru thanks a lot for givng your time. Bryan, it seems that you use dots for jumpers. I am going to build it today. Will convey you about the results. Warm regards, Amitraj |
#23 (permalink) | |
Experienced Member
I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
#24 (permalink) |
Hello all,
How do you do? Finaly I have built the Current Booster. Have not tested yet. I have come across following difficulty. Could somebody help me? There are 2 solar panels - each of 60W (12V). Now when I tested one of them at around 2.00 pm in India (this is summer in India and the temparature at 2 pm is usually around 40 Degree Celsius), I read 20V output. Now, when a variable resister of 2K (100W) was connected and readings were taken for different values, the range of output voltage across the resistor was:18.6 to 18.22. When I measured the current flowing through it was hardly in mA. e.g. 2 mA most of the times. Now as per the ratings the solar panel can source 5A. Could you guide me how to be confirm that the solar panel is providing this much current? The person who sold me the panels, says that 20V output is purposefully provided instead of 12V!!! Warm regards, Amitraj |
#25 (permalink) |
Experienced Member
18V across 2k ohms makes a current of only 9mA.
12V across 2.4 ohms (60W) makes a current of 5A. The solar panel must be outdoors and pointing directly at the sun at noon.
Uncle $crooge |
#26 (permalink) | |
Experienced Member
| Current source | GagoX | Electronic Projects Design/Ideas/Reviews | 13 | 12th January 2008 06:32 PM |
| H-Bridge: Current Sensor Placement | dknguyen | Robotics Chat | 16 | 7th December 2007 11:52 PM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 05:35 PM |
| Current and Conductivity | ElectroMaster | Electronic Theory | 1 | 2nd February 2007 12:50 PM |
| Bridge Rectifier Current Rating -- How much is enough? | hamfiles | General Electronics Chat | 6 | 6th August 2003 06:15 AM |
