LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
why Commercial Power Inverters is Compact and Light if we try to Build Ower Own 1200Watt Converter we need a Huge 10Kgs at lest transformer to handel the 100A Current but the commercial One weight only 4Kgs and soooooo Comapct How they do this ?
Compare these 2KVA Home Made Inverter ![]() AND 2500 Watt Commercial Inverter ![]() |
#4 (permalink) |
What i know aboat the inverter
12v dc -> convert it to ac using oscaltors and transistors -> transform it to 220 v ac using transformers So we need a big transformer that handel the big current (2500W Will Produce 250A) So How do they do it in commercial Inverters? |
#6 (permalink) |
Experienced Member
You can't use those transformers at high freq, this generally requires custom-wound jobs. There are a lot of "critical" factors here like wire gauge, core type/size, transistor drivers, board layout, and switching freq that require careful consideration. Skin effect is a limiting factor.
So you end up losing the problem of requiring a huge transformer core and a crazy amount of copper wire, but at the same time trade it off for a whole slew of new design issues. Larger supplies sometimes use multiple smaller transformers rather than one large one. Note the discrepancy between "peak" and "continuous" ratings in these inverters. The output is often exaggerated. Honestly there's no advantage to the idea of building an inverter nowadays. It would be incredibly expensive and probably wouldn't perform for crap, not the first few tries anyways. If you don't know what you're doing you could blow it up dozens of times. There's a lot of reasons to learn how to build switching power supplies though.
I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
#8 (permalink) | |
Super Moderator
#9 (permalink) | |
Experienced Member
http://www.ece.ualberta.ca/~knight/e.../vsi/spwm.html |
| Home made PCB's | markland556 | General Electronics Chat | 27 | 22nd February 2008 02:31 PM |
| Guys this is my home made 2.1 Home Theater System | pasanlaksiri | Electronic Projects Design/Ideas/Reviews | 17 | 18th February 2008 03:22 AM |
| Best home made security circuit | flemmard | General Electronics Chat | 6 | 11th September 2007 07:04 PM |
| Home made PCB:ferric chloride concentration | darvaish | General Electronics Chat | 2 | 14th March 2005 02:08 PM |
| home made etching tank..what u think | theboss | Electronic Projects Design/Ideas/Reviews | 2 | 12th April 2004 05:52 PM |
