Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 16th March 2008, 09:01 AM   #1 (permalink)
AboZakaria is on a distinguished road
Default Commercial VS Home Made Inverters
why Commercial Power Inverters is Compact and Light if we try to Build Ower Own 1200Watt Converter we need a Huge 10Kgs at lest transformer to handel the 100A Current but the commercial One weight only 4Kgs and soooooo Comapct How they do this ?
Compare these
2KVA Home Made Inverter
AND
2500 Watt Commercial Inverter
AboZakaria is offline   Reply With Quote
Old 16th March 2008, 12:40 PM   #2 (permalink)
Super Moderator
Because commercial inverters use high frequency switch-mode techniques, not low frequency like you use.
Old 16th March 2008, 01:00 PM   #3 (permalink)
Experienced Member
Brian Hoskins is a jewel in the roughBrian Hoskins is a jewel in the rough
Send a message via ICQ to Brian Hoskins Send a message via MSN to Brian Hoskins
That design is a decade old. The author says himself that a lot of improvements could be made with modern technology. He says that a redesign is required to modernise it.
Brian
Brian Hoskins is offline   Reply With Quote
Old 16th March 2008, 07:30 PM   #4 (permalink)
What i know aboat the inverter
12v dc -> convert it to ac using oscaltors and transistors -> transform it to 220 v ac using transformers So we need a big transformer that handel the big current (2500W Will Produce 250A) So How do they do it in commercial Inverters?
Old 16th March 2008, 08:13 PM   #5 (permalink)
Super Moderator
Try reading my previous post, high frequency means small transfomers.
Old 17th March 2008, 05:52 AM   #6 (permalink)
Experienced Member
Oznog is just really niceOznog is just really niceOznog is just really nice
Send a message via AIM to Oznog
You can't use those transformers at high freq, this generally requires custom-wound jobs. There are a lot of "critical" factors here like wire gauge, core type/size, transistor drivers, board layout, and switching freq that require careful consideration. Skin effect is a limiting factor.
So you end up losing the problem of requiring a huge transformer core and a crazy amount of copper wire, but at the same time trade it off for a whole slew of new design issues.
Larger supplies sometimes use multiple smaller transformers rather than one large one.
Note the discrepancy between "peak" and "continuous" ratings in these inverters. The output is often exaggerated.
Honestly there's no advantage to the idea of building an inverter nowadays. It would be incredibly expensive and probably wouldn't perform for crap, not the first few tries anyways. If you don't know what you're doing you could blow it up dozens of times. There's a lot of reasons to learn how to build switching power supplies though.
Oznog is offline   Reply With Quote
Old 17th March 2008, 12:51 PM   #7 (permalink)
But the AC must be 50 or 60 hz So what they do to solve this problem and if any one have a schematic or at least block diagram for a commercial inverter
Old 17th March 2008, 01:13 PM   #8 (permalink)
Super Moderator
They either rectify it to DC, then chop it at 50/60Hz to give a simulated rough sinewave - or, on better quality units, use it as a class-D amplifier and feed a 50/60Hz sinewave through the system, removing the high frequency carrier with an LC filter (which will need a fairly large choke).
Old 17th March 2008, 02:21 PM   #9 (permalink)
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
If you chopped it at 60Hz, you could only ever get a 60Hz square wave (easy and cheap, but far from ideal and large because of the low frequency). If you chop it at a higher frequency like 6000Hz with a filter and vary the duty cycle sinusoidally, you produce a sinusoid.
http://www.ece.ualberta.ca/~knight/e.../vsi/spwm.html
Old 18th March 2008, 09:09 AM   #10 (permalink)
thanks alot
Old 7th April 2008, 03:06 AM   #11 (permalink)
HS3
Experienced Member
HS3 has a spectacular aura about
Google for "magic sinewaves"
HS3 is offline   Reply With Quote
Home made PCB's markland556 General Electronics Chat 27 22nd February 2008 02:31 PM
Guys this is my home made 2.1 Home Theater System pasanlaksiri Electronic Projects Design/Ideas/Reviews 17 18th February 2008 03:22 AM
Best home made security circuit flemmard General Electronics Chat 6 11th September 2007 07:04 PM
Home made PCB:ferric chloride concentration darvaish General Electronics Chat 2 14th March 2005 02:08 PM
home made etching tank..what u think theboss Electronic Projects Design/Ideas/Reviews 2 12th April 2004 05:52 PM
