Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 15th March 2008, 10:24 AM   #1 (permalink)
AboZakaria is on a distinguished road
Default Is this Cicuits Works ?
hi all
I have seen this Cicuits(A 30 A Power Supply) and i wonder if its realy works and if its works can we replace the transistors(witch only pass current) with only a thick wire
http://www.zen22142.zen.co.uk/Circui...er/1230psu.htm
AboZakaria is offline   Reply With Quote
Old 15th March 2008, 11:29 AM   #2 (permalink)
Experienced Member
mvs sarma is a glorious beacon of lightmvs sarma is a glorious beacon of lightmvs sarma is a glorious beacon of lightmvs sarma is a glorious beacon of lightmvs sarma is a glorious beacon of light
Send a message via MSN to mvs sarma Send a message via Yahoo to mvs sarma
A relay will shrot circuit the Regulator IC.
Imagine 29.5 amps passing thro' a resistor( assuming the contact works like a resistor) across the 7805. if the contact resistance is taken as 0.1 ohm, there is a 3V drop across it. and burns around 90watts (29.5*29.5*0.1) at the contact point itself and the contact gives you a beautiful fireball.
Regards,
Sarma.
mvs sarma is online now   Reply With Quote
Old 15th March 2008, 03:19 PM   #3 (permalink)
Experienced Member
audioguru is a name known to allaudioguru is a name known to allaudioguru is a name known to allaudioguru is a name known to allaudioguru is a name known to allaudioguru is a name known to all
The TIP2055 power transistors continuously adjust their conduction as controlled by the voltage regulator so that the output voltage remains at 12V when the load current changes.
The voltage regulator cannot control the amount of conduction of a piece of wire.
Many power transistors are used to share the current and to share the heat.
Old 16th March 2008, 08:47 AM   #4 (permalink)
thanks alot
Old 16th March 2008, 11:55 AM   #5 (permalink)
IQBALSOUND is on a distinguished road
I have tried this circuit but failed a couple of times at 12 amp as regulator gives up then i use a diode and 800mA fuse in series insted of 1 amp fuse ,and successfully get 18 amp.
LINUX leads
iqbalsound@yahoo.com
92-321-9207460
IQBALSOUND is offline   Reply With Quote
Old 16th March 2008, 02:57 PM   #6 (permalink)
Experienced Member
It is a stupid circuit:
1) Its transformer's voltage is way too high.
2) The regulator has hardly any current (it won't give up unless it doesn't have a heatsink then it shuts down when it gets too hot).
At 5A each, the power transistors will have a base-emitter voltage of about 1.3V and the 0.1 ohm emitter resistors will have about 0.5V. Then the 100 ohm resistor and the regulator will have a current of about 18mA.
Old 7th May 2008, 08:20 AM   #7 (permalink)
scientist36 is on a distinguished road
that circuit is failure,try to change conect basis of transistor to the output of 7812 and add capasitor to ground,the collector of transistor conect to input of 7812 and then emitor as output the psu with adding a capasitor,try with 6 or more npn 2N 3055 transistor paralel to make high current,that will work,
scientist36 is offline   Reply With Quote
Old 7th May 2008, 09:14 AM   #8 (permalink)
Experienced Member
bryan1 is just really nicebryan1 is just really nicebryan1 is just really nice
As the OP showed in his schematic is a mains input WHAT DOES THIS HAVE WITH ALTERNATE ENERGY.
THIS BELONGS IN THE TRASH
sworry for shouting but my point remains
bryan1 is online now   Reply With Quote
My button works like magic, I only have to hover my finger over it jimfraseruk Micro Controllers 31 13th August 2007 07:42 AM
AVR simulator it works withowt assempler as 8051 simulator kasser Micro Controllers 3 14th February 2007 04:21 PM
Randomness of 16F84 program - sometimes works somtimes doesn FusionITR Micro Controllers 10 28th February 2006 09:06 AM
what works in the simulator does not work on hardware??? spyghost Micro Controllers 7 26th May 2004 11:15 AM
how does the transister works Faisal__saf General Electronics Chat 2 9th June 2003 07:12 PM
