Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 8th March 2008, 09:55 AM   #16 (permalink)
Experienced Member
rjvh is a jewel in the roughrjvh is a jewel in the rough
Originally Posted by I²R
Well, that's what a UPS is. I just bought a brand new APC 1300 kVA UPS for about $150
tested and guaranteed, why making one???
rjvh is offline   Reply With Quote
Old 8th March 2008, 02:44 PM   #17 (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
The mains power in Karachi is very unreliable the power companies turn it off because of late bill payments or outright theft, a UPS is designed for rare power failures and will draw more power as it recharges between losses. Why not buy a generator instead?
http://www.dailytimes.com.pk/default...7-3-2008_pg5_7
http://news.bbc.co.uk/1/hi/world/south_asia/7280933.stm
Bill
Smart Kits build Smart People
blueroomelectronics is online now   Reply With Quote
Old 12th March 2008, 11:34 PM   #18 (permalink)
Experienced Member
hackableFM is on a distinguished road
I agree with the comments above, It will be cheaper by far to buy one than make one!
If you insist on making one then the easiest way would be to buy your inverter and run it on battery constantly, but build a charger for the batteries which can supply more current than the inverter can use. This type of UPS has absolutely no dropout what switching over to battery.
I think they call this an 'Online' UPS. If you build an inverter that switches over to battery when the mains fails then they call these 'Offline' UPS's.
I personally have a UPS pretecting my machine but I was VERY lucky in that I picked it up from a local junk stall for £1. Yes you see correctly £1.00 Fair enough this one needed a new set of batteries but they only cost £20. Maybe you should keep looking around on junk stalls, You never know what you might pick up!
hackableFM.
When God was handing out the brains, I thought he said trains, so I asked for a small, slow one!
hackableFM is offline   Reply With Quote
Old 7th April 2008, 03:24 AM   #19 (permalink)
HS3
Experienced Member
HS3 has a spectacular aura about
My desktop and CRT, although they are rated much higher, actually only consume somewhat less than 200W. I have a 500 W UPS which came with a tiny 7AH battery which was just enough time to save your work when the power failed. When that battery failed, instead of replacing it with a similar one I got an old car battery. A battery which is unable to crank a car, specially a diesel, will still have plenty of life in it, has much more capacity than 7 Ah and it is FREE! Still, I do not expect to be able to work for hours, only that it may solve short blackouts or give me time to save my work.
If you want to maximize time off grid at the lowest price I would (1) get a laptop with a 12 V adapter and (2) install a bank of old car batteries. You can't beat that combination.
HS3 is offline   Reply With Quote
Old 7th April 2008, 03:32 AM   #20 (permalink)
HS3
Experienced Member
Originally Posted by Papabravo
A bouncing relay would never be fast enough.
My Ellipse 500 has a relay as do many others. The charge in the computer's PSU capacitors is enough to carry through the time it takes the relay to switch and the inverter to start up.
By the way, I also used to post at that other board but I left in disgust.
Old 10th April 2008, 01:20 PM   #21 (permalink)
Experienced Member
mashersmasher will become famous soon enough
it might work out if you can scrounge the bits from crap. maybe an old car battery being charged by a pc power supply and an old inverter could do the trick
mashersmasher is offline   Reply With Quote
Old 10th April 2008, 06:53 PM   #22 (permalink)
Experienced Member
Super_voip is on a distinguished road
I don't know what sort of PC HS3 has but I have recently been measuring PC wattages and have found that my old PC 1.4GHz with 19"CRT uses 150W,
newer quad core 2.4GHz with two LCD screens used 45W, with a decreasing power consumpution for newer PCs. The start up watts would be higher these are just the steady operating watts averaged over a week, no power saving turned on, even the screens were left on.
A UPS shouldn't be involved in rebooting a PC, that is why you get a UPS, so if the power does fail then I would need a UPS to provide 150W until I started the genset.
Super_voip is offline   Reply With Quote
Pickit 2 - Build or Not 2 Build art-666 Micro Controllers 2 5th February 2007 11:40 PM
SMPS power suply modify or build plss Raducu General Electronics Chat 12 9th February 2006 12:53 AM
Build a GPS receiver? mindctrl General Electronics Chat 6 18th January 2005 07:02 AM
Looking to build a counting device fogno Electronic Projects Design/Ideas/Reviews 4 22nd April 2004 10:40 PM
Tring to build an infrared remote control...need help homemade Electronic Projects Design/Ideas/Reviews 1 19th March 2004 08:44 AM
SEO by vBSEO 3.1.0 (Unregistered)
