Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 28th January 2008, 08:09 PM   (permalink)
Relic is on a distinguished road
Default Solar for water pump?
I have a small battery driven water pump, for an 18.9 liter water jug. It takes 2 x 1.5 D batteries. I'm using duracells and they've lasted a long while.
I would like to try a bit of DIY solar and run this pump that way.
I have some limited abilities in electronics, but after lurking for a while, this appears to be the place to learn a lot.
Does anyone know of something cheap and dirty? Or better?
Relic is offline   Reply With Quote
Old 29th January 2008, 03:28 AM   (permalink)
Experienced Member
Marks256 is a glorious beacon of lightMarks256 is a glorious beacon of lightMarks256 is a glorious beacon of lightMarks256 is a glorious beacon of lightMarks256 is a glorious beacon of light
Check some science/military surplus magazines. my favorite is AS&S
There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
Marks256 is offline   Reply With Quote
Old 29th January 2008, 04:29 AM   (permalink)
Experienced Member
justDIY is a jewel in the roughjustDIY is a jewel in the rough
if the pump runs on 3v worth of alkaline batteries then converting it to solar shouldn't be a problem. replace the two alkaline batteries with three NiMH or NiCad batteries and get yourself a cheap 12volt solar panel. Don't worry about hooking up a 12v panel to 3.6v worth of batteries - it will not cause any harm. Connect the cells to the batteries through a rectifier diode (1n4001 or whatever, it doesn't really matter). Should be able to get this done for under $20 US, probably a lot less if you shop around on the solar panel.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline   Reply With Quote
Old 29th January 2008, 10:24 AM   (permalink)
Talking
Thanks Marks. Good link for a lot of hardware, etc..
Just DIY, that's the kind of thing I was looking for.
Now this will demo my limited abilities in electronics. (embarrassment looms)
Which way do I point the diode? Is that all there is to it? No need for any other parts or circuitry?
I can assemble and do bread board type stuff, I know very basic stuff like how to use a vom, etc.. Knew more at one point, but drifted away.
Now, I'm in revival mode.
Old 29th January 2008, 02:01 PM   (permalink)
Experienced Member
Relic,
the diode points toward the batteries and you place it on the positive wire coming from the panel.
this website is almost identical to what you want to do:
http://solorb.com/elect/solarcirc/aacharge/index.html
that person decided to use individual solar cells instead of a panel, either way is ok. I don't think buying raw cells is any cheaper, and certainly not as easy to work with.
these guys have a lot of surplus solar at low prices
http://www.goldmine-elec-products.co...ductSearchBy=2
Favorite numbers:
Old 29th January 2008, 02:15 PM   (permalink)
Thanks DIY!
That's exactly what I wanted.
There's a couple of places nearby that have cheap panels in that range.
I'll start on it later today.
I'll tell you when I get it working.
Old 30th January 2008, 04:51 PM   (permalink)
I found a supplier from a link in your link:
http://www.robotshop.ca/home/product...lls/index.html
This is cool:
http://www.robotshop.ca/home/product...r-battery.html
But over the $20.
And I don't learn anything. But maybe it has it's uses, too.
Can you recommend a cell or cells to use from that link?
Old 30th January 2008, 06:31 PM   (permalink)
Experienced Member
those are all thin film, aka pricey and inefficient
it would be cheaper to pay international shipping and get one from the US, esp since your buck is worth more than ours right now.
i like this one, although it is a bare panel, so you'll need to build some sort of enclosure for it
http://www.goldmine-elec-products.co...?number=G16390
this one looks good ... the cell is potted in resin, so it's weatherproof and somewhat durable, plus the leads are already soldered on
http://www.goldmine-elec-products.co...p?number=G4528
Favorite numbers:
Old 31st January 2008, 01:47 AM   (permalink)
I like the 6 x 6. I think I'll get 2 and have one to try something else with.
The 2nd thing I wanted to tackle was our electric toothbrush.
Are you familiar with their recharge unit?
Solar Battery Charger (you knew it would happen :D) Krumlink Electronic Projects Design/Ideas/Reviews 21 17th October 2007 09:41 PM
pl help regrding solar applications!!!!..... rupesh pawar Micro Controllers 2 12th October 2007 08:27 AM
Need Low Volume Water Pump Noggin General Electronics Chat 27 26th June 2007 04:32 AM
Help with manual pump! Please Help! turtleg Electronic Projects Design/Ideas/Reviews 6 10th April 2007 01:52 PM
Micro Pump regulator GarStar Robotics Chat 1 3rd April 2006 01:37 AM
