I learnt from the magazine that people had installed wind generator into a small helium ballon and sent it 100 meters about the ground. It will generate electricity power for two household use. I think it is cool and easier to install for your house. People will not complaint about the noise problem. | |
only problem is we have about 10 years of helium left on the planet, I wonder which we'll run out of first, indium or helium.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
Where will the helium gas go?
it gets out of the balloon and escapes into the upper atmosphere where it's impossible to recover
Then how do we collect the helium? Should they all gone by now?
| | #6 |
helium is mainly recovered from natural gas wells, but only a few producers bother, most just vent the helium with the other waste gases during the refining process.
| | #7 |
Helium is naturally found in the amptmosphere but extracting it isn't easy as it requires the air to be cooled until it liquifies, then is fractionally distilled.
| | #8 |
If I remember from correctly, I believe helium, along with hydrogen, is one of the gases that escapes from the atmosphere into space. The thermal energy in the atmosphere causes the atoms of helium to achieve escape velocity and leave Earth never to return.
| | #9 |
Helium is not present in large enough quantities to distill out of the air- not unless you invent free cryogenic refrigeration. If you had that, forget about generating electricity with wind power, we've got free air conditioning! Helium is only generated from nuclear isotope decay inside the earth. It is present in a small amount in all natural gas, however, despite its value there are only a few fields in the world with a great enough concentration to capture. The natural gas fields around Amarillo, Tx has been the primary source of helium, around 7%, for the entire world since 1925, but it's fast running out. There are only a limited number of other sources in the world and when they're gone, they're gone, and being an element there's no way to make more out of something else. Not unless you're going to use a nuclear reaction and that's way too slow.
| | #10 |
invest in helium futures on the NYSE
| | #11 |
Use hydrogen then. It's cheap, easily available and lighter. The only real drawback it its flammability but unless there are people present or a significant fire risk to persons or property, why worry? | |
| | #12 |
Lol?
__________________ IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S | |
| | #13 | |
| | #14 |
Helium is very expensive and you would need a lot of it to lift the turbine up into the air.
| | #15 |
And that is why the project never got off the ground | |
| balloon, generator, helium, wind |
| Would like help with voltage boost circuit for Wind Generator. | charles25 | Electronic Projects Design/Ideas/Reviews | 15 | 22nd December 2008 11:15 PM |
| My Wind Generator Project | chemelec | Alternative Energy | 17 | 16th September 2008 05:34 PM |
| Wind Generator - Star Delta Controller | simoin | Alternative Energy | 39 | 15th June 2007 02:24 PM |
| Cd's as wind generator | things | Alternative Energy | 16 | 13th June 2007 07:31 PM |
| ammeter for standby generator | jwnetsource | Electronic Projects Design/Ideas/Reviews | 4 | 3rd June 2006 06:30 AM |
