| Experienced Member | Quote:
you can't lose energy you only can transfer it to an other form and till the day of today you can't do it without loss but in the majority of all transformations the losses will be represented in thermal form | |
| Experienced Member | Yeah Nigel you're WAY off there. The lion's share of power goes into electronics and drives and stuff. There's a fraction of a watt in desired sound out of the speakers in typical use, seeing as usually the PC makes a sound <1% of the time it's actually much less total power. Your monitor estimate is also way off. Well, if you've ever seen a 5W LED flashlight it really lights up the room and IIRC that's only about 1W of actual light energy. So I'd say a CRT actually puts out light on the order of 1W of light energy. Again, using a Kill-A-Watt- a big desktop with a 21" monitor can suck down 250W continuously easy. I've been in computer rooms though where they spent a lot to make the air conditioning REAL cold for the servers to lower the MTBF.
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
| Super Moderator | Quote:
| | (permalink) | |||
Did you read my post about a 100W light bulb? A 100W light bulb only gives 2.6W of light and I don't know how many times brighter it is than TV with a white screen; given the eye's logarithmic response, I'd estimate it's ten times a bright, that's 260mW of light. | |||
| Experienced Member | electricalpower consumption is measured in watt but light is measured in candela and the amount of light that is send (Reflected) in a certian angle is mesured in lumen and yes a LED is far more efficient in producing light in the visible spectrum than a crt does don't forget that a crt also emit x rays that is a spectrum we can not see but it it takes the energy for producing it the output in the for human visible spectrum is just a part from the total spectrum it emits Robert-Jan |
It is difficult to equate an LED to an incandescent bulb for the reasons you give but, the discussion is about power efficiency and thus, taking into account the "wasted" power (heat rather than light) is valid. The CRT (and associated parts...circuitry, filament, grid power, sweeping, high voltage, beam resistance, shadow mask losses, phosphor efficiency, etc.) uses power and one of those is X-ray emmission. But, again, for purposes of the direction this discussion has gone, they all result in heat and virtually all that heat is sinked by the room (and eventually by the world and then the universe at large). So, while the things you say are true, I'm not just sure of the point you are making about the heat load contributed by the aappliances in a home. | |
| Experienced Member | straying off the subject is happend quit a few replies aggo when it shifted to the effect a LED has on what we can see and a CRT in the same set up i agree and mentioned in an earlyer reply that the majority of energy transformations has losses in a thermal form and so warm up the envoirment (as big as that you will name it ) now i just wonder (and i agree this is straying off topic) with an ever expanding universe doesn't that mean to keep the avarage temp the same we have to produce heat energy otherwise we freez to death at a certain time Last edited by rjvh; 15th January 2008 at 09:32 AM. |
Of course the universe will cool as it expands (and radiates away light-speed energy, which will never be recovered...at least that's my SWAG (silly, wild-ass guess)). I'm writing a paper on the universe and I think the 3 degree background radiation is a cool remnant of an earlier iteration of our universe. But, THAT's really getting off topic! | |
I can read by an LED flashlight at from quite a ways away, with it illuminating a pretty decent area, a few sq feet. Usually those should be around 4V @ 20mA, 10% efficient could be 8mW of light.
