| Experienced Member | We don't use Ammonium Chloride. We use either, Liquid Ammonia and Water in a Hydrogen atmosphere. or, Lithium Bromide and water. or, Lithium Chloride and water. The nice thing about Lithium (Br or Cl) is that you can use the sun to concentrate the solution and store the concentrate as long as you wish, effectively giving you cooling on demand. Mike. |
| Experienced Member | Hiya Mike (Pommie), When you say 'we' do you mean your involved? As I'm very interested in developing my own RE based aircon but the first sticking point is to legally get Ammonia I need to get a licience first and be a registered business to be able to get it. The business part isn't a problem just the red tape is. Now is Br of CL readily available here in Oz and does the same rule apply?. Anyway I've talked on irc to 3 guys who made the solar ice maker and they all said it worked perfect and they average around 20-30 pounds of ice a day. Nigle's quote of 'it's just not viable' is a typical response from a city slicker who only needs to turn a knob on their aircon for cooling. For us R.E mob life aint that simple for example: my 3kw pure sinewave inverter with a 9kw surge wont start the aircon in my shed. Cheers Bryan Our main fridge in our house is an absorbant ammonia one and even when it's 43C in the shade the fridge itself is still sitting on 2C. The only drawback is it's only a 290 litre fridge and that was the biggest available 4 years ago when we got it. I did a trial last year on it by turning off the gas pilot light and throwing a 100 watt globe in there and yes the fridge still worked
__________________ " The only way to avoid human error is to avoid the use of humans" |
| Experienced Member | Hi Bryan, I used the term 'we' as I was answering the previous posters question "why do we use amonia chloride solution ?" I am not involved but have had the intention to get involved for a few years, just never got around to it. As far as obtaining Br and Cl (both nasty substances), I think you will have a problem. The good news is you don't need them, you need Lithium Chloride or Lithium Bromide (both harmless powders). On a non industrial scale, Lithium Chloride can be made from Lithium Carbonate (Pottery supplier) and hydrochloric acid. For larger amounts a chemical supply company should be able to supply either with no restrictions. The main drawback is that both are lithium salts and are therefore corrosive. Mike. |
| Experienced Member | Hi Mike, First thanks for the quick reply Cheers Bryan
| Experienced Member | make sure your valves are also SS also your pipe should be thick enough to withstand pressures up to 12 bar (175 PSI) |
| Experienced Member | Quote:
Mike. | |
| Experienced Member | and how much is your underpressure?? vacuum is just negative pressure |
| Super Moderator | Quote:
If you would prefer me to be more accurate, it's not 'financially' viable - if you live in the middle of nowhere financial viability isn't a concern - just something that works is. | |
| Experienced Member | england what about a sollar water heater for your hot water supply the problem with england is the same as holland (where i am orriginaly from) lack of sun hours |
Mike. P.S. what is negative pressure? | |
| Experienced Member | Ammonia systems do work in real time. Check out any gas powered fridge, they use a small gas flame to run the refrigerator. Mike. |
| Experienced Member | negative pressure is suction and for the ice storage it can cool your house but do it properly you have to think about it with the building design of your house water walls or piping with water circulation is a good option but a head ache in an exsisting house |
All systems cycle. All systems can be made to work in real time. They just get a bit more complex. Mike. | |
| Solar Power LED Array (Dead Simple) | simoin | Alternative Energy | 21 | 25th November 2007 11:13 AM |
| Solar Battery Charger (you knew it would happen :D) | Krumlink | Electronic Projects Design/Ideas/Reviews | 21 | 17th October 2007 09:41 PM |
| pl help regrding solar applications!!!!..... | rupesh pawar | Micro Controllers | 2 | 12th October 2007 08:27 AM |
| Solar battery charger with moving panel | Hanford | Electronic Projects Design/Ideas/Reviews | 6 | 8th October 2006 01:38 PM |
| Solar Car | Archangel4life | Electronic Projects Design/Ideas/Reviews | 4 | 31st March 2004 07:31 AM |
