| Experienced Member | if hydrogen is available, Ford and BMW will make you a hydrogen powered vehicle.
__________________ Funny N., Au Group Electronics, USA, www.AuElectronics.com |
| Experienced Member | Quote:
For the most part, sun shines, wind blows and waves crash...and the tides come in and go out and water falls from the sky and rushes to the sea and the magma under the earth will still be hot long after humans have run their course here on Earth. The question is: Will we do both the easy giant and not so easy baby steps to try to extract as much of that energy as we can with the minimum impact on the Earth or will we throw up our hands in frustration that baby steps are hard and just continue drilling for oil and digging for coal and cutting down forests and collecting cow farts for fossil/bio-fuel energy sources? I know this isn't exactly the technical discussion of the topic but, I beleive it is the precursor to the technical thinking that will be needed to make the tough energy sources viable. Last edited by crashsite; 23rd January 2008 at 03:23 AM. | |
| Experienced Member | What are the chances of a nuclear bomb blowing up somewhere near my house? About 1 to 100,000,000. And the wind 1 to 4. The sun does shine most of the time, but when it doesn't????
__________________ Regards, William Mullaney "HOPE for the best, EXPECT the worst, ACCEPT whatever comes." http://wiliamsville.myminicity.com/ http://wiliamsville.myminicity.com/ind/ http://wiliamsville.myminicity.com/tra/ |
Regarding the chances of a "harmless" nuclear explosion near your home. Well, the odds are still better than Jessica Simpson having an intelligent thought (so, how come she has more money than I do?...........Oh, yeah, those). Last edited by crashsite; 24th January 2008 at 11:24 PM. | |
| Experienced Member | How much hydrogen can you get from a solar powered splitter? Or just for a test, a 9v battery?
| Super Moderator | Quote:
The following calculation is based on conventional chemistry. For more detail, see these links (among hundreds): http://www.science.uwaterloo.ca/~cch.../nernsteq.html http://www.nmsea.org/Curriculum/7_12...ectrolysis.htm For those who are not too picky and don't want to get wound up in what are basically unit conversions, consider the following equations: H2O = H2 + ½O2 Eo = 1.229 V ; and 2H+ +2e- = H2 To get one molecule of hydrogen, H2, from 2H+ you have to provide 2 electrons. A mole of hydrogen occupies 22.4 L at STP (approximately 29.92 inches of Hg at 32° F Doing the math, production of 1L of hydrogen requires 5.4X10E22 electrons or approximately 8,700 coulombs. Assume your 9V battery is rated for 500 mAH ( I am too lazy to look up a real value). An hour is 3600 seconds. A current of 0.5 A for 3600 seconds is 1800 coulombs. Thus, your 1800-coulomb-capacity battery will produce a maximum of 200 mL of hydrogen gas at STP. Efficiency is probably a lot less than 100%, so individual results may vary. If you are more comfortable with electrical nomenclature, the Faraday is 96,489 coulombs per mole. Since production of H2 reuires 2e per mole of gas, then 192,978 coulombs are required per mole of gas. At STP, a mole is 22.4 L (same as above), so a liter will require 8600 coulombs. The difference is due to rounding. The simple answer: A 9-V non-rechargeable battery is an expensive way to produce just a little hydrogen. John edit: better defined which battery type Last edited by jpanhalt; 25th January 2008 at 06:06 PM. | |
The numbers you cite suggest that it's sort of on the edge of practicality but, at the present state of the art, probably still on the "not practical" side. | |
Practical for what?? Running an internal combustion engine, no. A fuel cell, IF you could find a decent way to store many pounds of hydrogen and have a cheap, plentiful source of electricity or some exotic way of generating H2 like algae, sure it could be practical. Electrolysis becomes electrically more efficient at high temps, where it absorbs some of the heat energy cooling the solution down so it requires more high-temperature heat and high temp heat isn't often free. There's certainly a lot on making better electrolytic cells. They usually use a very alkaline solution too. But, its electrical power requirements are still quite high.
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. Last edited by Oznog; 27th January 2008 at 06:36 AM. | |
Well, I suppose this topic has pretty much been beat to death, eh? | |
| New Member | Quote:
I've seen it spread on ground here in N Ireland, complete with condoms and sanitary waste. I believe it is regularly spread as fertiliser here! | |
| Experienced Member | The main problem with using relatively untreated human waste as fertilizer is infectious diseases. Appropriate food preparation helps, but doesn't entirely eliminate the risk. Viruses, parasites, and bacteria are the main etiologic agents of concern. We had a major outbreak of hepatitis from green onions at a popular Mexican restaurant a few years ago. They were imported from an area that used human waste as fertilizer. Parasites (e.g., cryptosporidium, etc.) can also be a problem if the food is under cooked or not properly cleaned. And of course, you have probably heard of cholera, E. coli O157; H7, typhoid fever, and others. One species’ pathogens are often less infectious for other species than for its own species. What you don't want to do is create a cycle of infection in the same species. It is better to use cow dung for human food crops unless there is good control of the processing of the human waste. However, the purveyors of s__t may not pay much attention to regulations. In spacecraft, there is much better control of the environment, the occupants, vaccinations, sanitation protocols, etc. John |
| Setting stepper motor to 'home' position. | MrNobody | Micro Controllers | 14 | 3rd October 2007 03:03 PM |
| usb interfacing problems for a waveform generator | simonharvey | Electronic Projects Design/Ideas/Reviews | 0 | 26th September 2007 11:31 PM |
| HYDROGEN GENERATOR - fuel cell ? | badspell68 | Alternative Energy | 67 | 3rd June 2007 10:10 PM |
| ammeter for standby generator | jwnetsource | Electronic Projects Design/Ideas/Reviews | 4 | 3rd June 2006 05:30 AM |
| Wide Band Signal Generator | CParsec | General Electronics Chat | 1 | 27th September 2003 02:48 AM |
