Here in Texas windmills (power not water) are becoming common, especially in West Texas.
http://www.flickr.com/photos/unwiredben/14425149/ The link show a high altitude photo of a string of power production windmills. The blades on each windmill is about 60 feet in length (that 2 blades = 120 feet). Wind is viable...but hardware cost, space, dead birds can each present issues. Personally I wish a small H2 generator was viable. I do remember some years ago reading about someone that had commercially produces a welding rig that used H2 generator. It was produces as 'Brown's Gas'. I thought for a while someone would take this and do something but nothing that I have heard of. Also, I seem to remember from chemistry class (early 1970's) my instructor talking about H2 production and said that it did not matter if you used 1.5vdc or 300vdc that the production would not progress faster with more voltage. This had always bothered me because logic says different but I never had a chance to test this. Does anyone know if this is the case? RLJ |
In regard to the weather pattern. Power generation from wind is very passive. Think about the huge amount of heat released by a coal fired power station. That would have a much larger impact then slowing the wind down bit. Wind is driven by existing heat energy. By harvesting that energy instead of burning carbon ... what ? |
One the problems we are experiecing in the UK with wind turbines, is the accumulation of dead 'bugs' on the leading edge of the blades. The dead bugs provide a soup for the build up of micro organanisms, which cause a large drop in efficiency by spoiling the aerofoil section of the blade. They have had to install anti bacterial sprays on the towers to spray the blades from time to time.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
I don't believe that low population density is a very acceptable excuse for doing something as disruptive and potentially disruptive to the environment and fauna as would be produced by widespread use of windmills. Not-in-my-backyard logic has a way of becoming everyone's problem. It is a straw-man argument to justify wind power based on comparison to a single alternative: inefficient coal-based plants with lots of heat loss. There are other alternatives, including but not limited to nuclear and gasification. As for the effects from "slowing the wind down a bit," I am less optimistic they would be negligible. A 1 °C increase in global temperature, which is less than a 0.5% change, has been predicted to have an enormous impact. Turbulence and direction of wind also affect weather, not just velocity. John |
I know this is off topic a little but here is possible reply to the last post...
http://www.quietrevolution.co.uk/qr5.htm RLJ |
(permalink) | |||
How do you see this as a "Not-in-my-backyard" deal when the people who own the land want the turbines. If you do not own a pasture or a wheat field you have no reason to live in one. The people who own this land would greatly benefit form the income. Population centers are often 20 or more (much more) apart. Lots of room for turbines. How do you see the a wind turbine as causing global warming. You are uninformed. Global Warming, Clean Energy Solutions: Wind Energy The Sierra Club Quote:
And as pointed out by RLJ in the previous post quited turbines are possible for areas where that would be a problem. That makes them even more of possible solution. |
(permalink) | ||
(permalink) | ||
It is difficult to take you seriously when you toss out remarks like the following.
Large building block the wind, vast expanses of pavement trap rather the reflect the solar energy. What about deforestation of the rain forests. The farmland that replaces it will have a vastly different heat absorption rate then the trees. The point is we effect the solar/wind of the planet in many ways and directions. Current thinking is that there will be increased violent weather due to global warming. Maybe reducing the wind speed a bit would moderate that. It would be nice. We know buring less carbon will help moderate it and wind farms will help with that. If you think there is a real problem with the possible wind slowing due to turbines find some evidence to support it, then put it perspective. To say so without is fear mongering. Collected and re-purposed solar/wind energy is about as close as you can come to zero environmental impact. |
Ha, doesn't work, does it? (I had the same problem)
Regards, William Mullaney "HOPE for the best, EXPECT the worst, ACCEPT whatever comes." http://wiliamsville.myminicity.com/ http://wiliamsville.myminicity.com/ind/ http://wiliamsville.myminicity.com/tra/ |
Ya, read your post.
"Brown's Gas" is the mixture of H2 and O2 you get out of electrolysis when you don't capture the bubbles forming on the 2 electrodes with 2 separate jars. It doesn't have any of the magical energy properties touted by the "free energy" crowd. The rate of gas production depends primarily on current. Current does increase with increased voltage, but voltage alone doesn't increase the rate. For example using an electrode of half the surface area will require more voltage for a given current, but the extra voltage to produce say the same 5 amps will not increase the rate of gas generation.
I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
I guess I have a little trouble believing that "baby steps" are useless. I'm thinking that 20 million homes, each with a 100 Watt solar panel could pump an average of 100 MegaWatts into the power grid (5 Watts per panel with most of the power being generated during peak load (industiral max) times). Same concept with home hydrogen generation. Where's that darn Yankee ingenuity we Americans keep bragging about (and others keep insisting that they do even better)? |
But what if there's no wind? We get wind every 3-4 days, what if it's overcast?
| Setting stepper motor to 'home' position. | MrNobody | Micro Controllers | 14 | 3rd October 2007 03:03 PM |
| usb interfacing problems for a waveform generator | simonharvey | Electronic Projects Design/Ideas/Reviews | 0 | 26th September 2007 11:31 PM |
| HYDROGEN GENERATOR - fuel cell ? | badspell68 | Alternative Energy | 67 | 3rd June 2007 10:10 PM |
| ammeter for standby generator | jwnetsource | Electronic Projects Design/Ideas/Reviews | 4 | 3rd June 2006 05:30 AM |
| Wide Band Signal Generator | CParsec | General Electronics Chat | 1 | 27th September 2003 02:48 AM |
