Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 13th November 2007, 01:14 AM   (permalink)
Experienced Member
Boncuk is just really niceBoncuk is just really niceBoncuk is just really nice
Send a message via MSN to Boncuk
Default Wind generator
Since the day lasts for 12 hours it's unlikely it'll become heavilly overcharged.
The wind ignores day time and blows whenever it wants. It usually blows 24 hours per day (worst case). So the chances for overcharging a battery are pretty high.
Boncuk is offline   Reply With Quote
Old 13th November 2007, 06:40 PM   (permalink)
Experienced Member
Helder Ferreira is on a distinguished road
You can add more batteries and find a way to use the extra "juice". The difficult part of the job (erecting the generator), you've already done, so, try to find out the efficiency of the system and put it use. A shunt regulator will "waste" "precious" energy by transforming it to heat.
Helder Ferreira is offline   Reply With Quote
Old 13th November 2007, 09:11 PM   (permalink)
Experienced Member
HarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to all
For this one, I want to keep an ATTiny13V running an RGB LED fading program, pretty much continously. The AVR is low voltage, and doesn't draw much current, less than 4mA. The LEDs will be high brightness 20mA. Hoping to get over 100mA out of a small stepper. Going to throw it together while on vacation in another week. I don't think I'll be able to make any measurements when its outside on a pole, but was thinking of hooking up a motor to spin the propeller while its on the bench, but that would mean build some sort of speed control... Probably just put it outside and see what happens.
HarveyH42 is online now   Reply With Quote
Old 14th November 2007, 07:35 AM   (permalink)
Experienced Member
Measurements should be quite easy if you happen to have a fan. A 16 inch dia
fan will do.
Wind Generator - Star Delta Controller simoin Alternative Energy 39 15th June 2007 01:24 PM
Xbox 360 Tilt Controller adamthole Electronic Projects Design/Ideas/Reviews 0 20th January 2007 05:24 PM
closed loop controller that receives set point updates TXRX usacanbiteme Electronic Projects Design/Ideas/Reviews 5 28th September 2005 09:02 PM
Help With Temperature Controller bryan Electronic Projects Design/Ideas/Reviews 4 30th June 2003 12:18 PM
PBX question waqar Electronic Projects Design/Ideas/Reviews 0 30th March 2003 06:21 PM
