| Experienced Member | Quote:
| Experienced Member | You can add more batteries and find a way to use the extra "juice". The difficult part of the job (erecting the generator), you've already done, so, try to find out the efficiency of the system and put it use. A shunt regulator will "waste" "precious" energy by transforming it to heat. |
| Experienced Member | For this one, I want to keep an ATTiny13V running an RGB LED fading program, pretty much continously. The AVR is low voltage, and doesn't draw much current, less than 4mA. The LEDs will be high brightness 20mA. Hoping to get over 100mA out of a small stepper. Going to throw it together while on vacation in another week. I don't think I'll be able to make any measurements when its outside on a pole, but was thinking of hooking up a motor to spin the propeller while its on the bench, but that would mean build some sort of speed control... Probably just put it outside and see what happens. |
| Experienced Member | Measurements should be quite easy if you happen to have a fan. A 16 inch dia fan will do. |
| Wind Generator - Star Delta Controller | simoin | Alternative Energy | 39 | 15th June 2007 01:24 PM |
| Xbox 360 Tilt Controller | adamthole | Electronic Projects Design/Ideas/Reviews | 0 | 20th January 2007 05:24 PM |
| closed loop controller that receives set point updates TXRX | usacanbiteme | Electronic Projects Design/Ideas/Reviews | 5 | 28th September 2005 09:02 PM |
| Help With Temperature Controller | bryan | Electronic Projects Design/Ideas/Reviews | 4 | 30th June 2003 12:18 PM |
| PBX question | waqar | Electronic Projects Design/Ideas/Reviews | 0 | 30th March 2003 06:21 PM |
