Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 4th November 2007, 02:35 AM   (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Send a message via Skype™ to Krumlink
Default Wind Generator Design
Well my dad and I were talking about creating a wind power generator for the house. I know to use a car Alternator, and a Power Inverter for everything, but I wanted to know some more details, and seeing how I dont even know the name of it, I think I might want to ask the forum before I spend hours on google sifting through windmills
I would like it to be able to go into the power inverter (12V I guess?) and step it up to 120AC. We have a little one for a car so I know IT can be done. maybe I will get some car batteries and have it hook up there and charge those then use that as a power source for our very energy craving house for about 2 minutes Actually I would use it for myself. I know how to wire up the house and stuff, but really just wanting to know the design and etc of one.
MechTronics
Krumlink is offline   Reply With Quote
Old 4th November 2007, 03:02 AM   (permalink)
Moderator
I know that if you spin a motor it generates voltage right? So if I put huge blades on a very large motor (3Amp No load) I could use that right?
MechTronics
Old 4th November 2007, 09:52 AM   (permalink)
Super Moderator
There are lots of links to wind powered generator sites in this forum, go and study some!.
You do need batteries, without a storage medium it's pretty useless.
Old 4th November 2007, 03:48 PM   (permalink)
Experienced Member
Your best bet is to try to cur your power consumption first, before you mess around with wind turbines.
Car batteries aren't really much use as they aren't designed to be discharged much.
Old 4th November 2007, 04:30 PM   (permalink)
Moderator
Hmmmmmm
What about a massive capacitor bank
Lead Acid Batteries?
MechTronics
Old 4th November 2007, 04:39 PM   (permalink)
Super Moderator
Originally Posted by Krumlink
Hmmmmmm
You couldn't afford them, and don't have enough room!.
Yes, but you should use ones specifically designed for deep discharging, not just cheap car ones.
However, if you can get hold of cheap car ones it will give you a chance to test the practicability of the idea.
Old 4th November 2007, 04:43 PM   (permalink)
Moderator
I think I like the Lead Acid batteries, and I could use the ones that my HS robotics team uses (they pull up to 100A). They are only 20$.
MechTronics
Old 4th November 2007, 07:30 PM   (permalink)
Moderator
Now for the Power generation part: How to produce around 12 Volts?
I could use several things for power generation, but do you know of any good ones?
Also, for the inverter, I could use a part, product, schematic, etc.
MechTronics
Old 4th November 2007, 09:48 PM   (permalink)
Experienced Member
Ideally you want a higher voltage than 12V, if you want to drive an inverter from it,. Generally the higher the voltage the better, 48V would be ideal as it's just about safe to touch with dry hands but failing that you could easilly settle for 24V.
For safety's sake, earthing both the DC and AC side is also a good idea as it won't float at a stupid voltage if the mains acidentally comes in to contact with it, it'll just blow a fuse/RCD/GFI and it'll make lightning protection circuitry easier to implement too.
Old 4th November 2007, 10:39 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
When the wind blows hard then the current will be 30A or more and the generator will burn out or the blades will fly apart. The battery might become severely overcharged or might boil.
You need a charge controller with something to limit the current from the generator. Then it stops charging when it detects that the battery is fully charged.
You also need something to limit the RPM of the blades.
Old 4th November 2007, 10:52 PM   (permalink)
Moderator
The motor I am thinking of is REALLY torquey, so that wont be a problem. Michigan is very wierd...
MechTronics
Old 4th November 2007, 11:07 PM   (permalink)
mynameisdan is on a distinguished road
For limiting the speed of the blades you can use a magnet brake.
mynameisdan is offline   Reply With Quote
Old 4th November 2007, 11:28 PM   (permalink)
Moderator
So would I just put magnets behind the blades that are mounted on the motor, far enough away not to affect the motor?
MechTronics
Old 4th November 2007, 11:41 PM   (permalink)
Try running a magnet over a peice of metal. The faster you go, the more you feel it's resisting. The further away your magnet it, the faster it will allow you to go.
The old trick is a dropping a magnet down a copper pipe.
Old 4th November 2007, 11:52 PM   (permalink)
Moderator
Ok thanks, I will take that into consideration. Thanks
MechTronics
How do wind a transformer FusionITR General Electronics Chat 16 31st March 2008 12:46 AM
Cd's as wind generator things Alternative Energy 16 13th June 2007 06:31 PM
Wind turbine blade designs Salaki Alternative Energy 31 17th May 2007 08:03 AM
Wind energy to electric energy Vaibhav Birit General Electronics Chat 192 28th July 2005 01:58 PM
Making a wind sensor xcfisher Electronic Projects Design/Ideas/Reviews 13 12th November 2003 05:36 PM
