Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 5th November 2007, 11:49 AM   (permalink)
Experienced Member
jpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nice
Originally Posted by mynameisdan
For limiting the speed of the blades you can use a magnet brake.
It might be easier to make the blades with controllable pitch. So-called constant speed propellors for aircraft have such blades.
Second, do not underestimate the drag force against your windmill. A free-wheeling propellor has a drag force approximately the same as a flat plate of the same area as the propellor's arc. Thus, an eight foot propellor (arc area about 50 ft^2) feee-wheeling in a 30 knot wind would have a drag force of about 200 # (See: http://www.sailingusa.info/cal_wind_load.htm). You may want a brake on the prop to stop it from turning in a strong wind or a method of turning the windmill parallel to the prevailing wind. Feathering the blades also acts as a brake and further reduces drag compared to leaving the blades at their normal pitch. John
jpanhalt is online now   Reply With Quote
Old 5th November 2007, 05:47 PM   (permalink)
Experienced Member
If you want to be clever you could design a turbine that eneables you to change the angle of the blades to limit the RPM.
Old 5th November 2007, 09:27 PM   (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Send a message via Skype™ to Krumlink
I was thinking about a system of solenoids with magnetic brakes on the end that could slow it down with a push of a button
About the Batteries, what:
Voltage
Amperage
Should they be?
Also, what should I use to generate the voltage?
MechTronics
Krumlink is offline   Reply With Quote
Old 6th November 2007, 09:04 AM   (permalink)
Experienced Member
Super_voip is on a distinguished road
Originally Posted by Krumlink
I think I like the Lead Acid batteries, and I could use the ones that my HS robotics team uses (they pull up to 100A). They are only 20$.
Or you could use AAA nicads they can supply a lot of current as well, really what you need is old telephone exchange batteries, they can supply a lot of current for a long time.
Super_voip is offline   Reply With Quote
Old 6th November 2007, 08:34 PM   (permalink)
Moderator
AAA NICADS may be too small for this scale. I am talking a few amps per hour, more than any NICAD for that matter could/would supply without overheating.
I like the Lead acid idea, and so does my Family.
I really need a generator now!
MechTronics
Old 6th November 2007, 11:04 PM   (permalink)
Experienced Member
mneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of light
Send a message via AIM to mneary
Your HS robotics battery is capable of providing high current for only a short time. Remember, the actual competition was 2 minutes, 10 seconds.
mneary is offline   Reply With Quote
Old 7th November 2007, 01:10 AM   (permalink)
Experienced Member
Leftyretro has a spectacular aura about
There are special NICAD batteries that can supply tons of current, used in R/C models for high performance motors.
Just a standard NICAD 'D 'cell is rated at 4 amp/hrs I seem to recall.
Lefty
Measurement changes behavior
Leftyretro is offline   Reply With Quote
Old 7th November 2007, 06:58 PM   (permalink)
Experienced Member
You want more than a few Ah which is what a typical AA NiMH cell can provide. You need a couple of hundered Ah at the very least.
Old 7th November 2007, 07:30 PM   (permalink)
Super Moderator
So does everybody else in the world - solar power, wind power - you use lead acid batteries, end of story really!.
Old 7th November 2007, 07:58 PM   (permalink)
Moderator
Besides, the most amount of watts I would be using at any one time would probably be a max of about 200Watts.
I need a way to generate the voltage now
MechTronics
Old 7th November 2007, 08:14 PM   (permalink)
Super Moderator
As you suggested in the first place, a car alternator is an easy place to start.
Old 7th November 2007, 08:40 PM   (permalink)
Moderator
How much would you think it would cost for a cheap one? I will have to check it out.
MechTronics
Old 7th November 2007, 09:37 PM   (permalink)
Experienced Member
Nothing, go to a scrap yard.
Also note that car alternators aren't very efficient.
Old 8th November 2007, 03:53 AM   (permalink)
Experienced Member
kchriste is a glorious beacon of lightkchriste is a glorious beacon of lightkchriste is a glorious beacon of lightkchriste is a glorious beacon of lightkchriste is a glorious beacon of light
A better solution than a car alternator would be to use a larger DC permanent magnet motor as a generator. If you want to use stuff from old cars, a radiator cooling fan motor may provide enough current as a generator. Years ago I made a windmill out of an old computer tape drive motor (Think large 1970s computer). I think the motor was designed to run from 24-48V so it put out 12V @ 10amps quite nicely at low RPMs.
kchriste is offline   Reply With Quote
Old 13th November 2007, 01:28 AM   (permalink)
Experienced Member
Boncuk is just really niceBoncuk is just really niceBoncuk is just really nice
Send a message via MSN to Boncuk
Hmmmmmm
What about a massive capacitor bank
Lead Acid Batteries?
Good point! WIMA has developed a capacitor not too big around with a capacity of 400F!
A 500F type is under development. One disadvantage they have: Charge is limited to 2.5V
The massive capacitor bank could be the garage filled with capacitors from bottom to top.
Boncuk is offline   Reply With Quote
How do wind a transformer FusionITR General Electronics Chat 16 31st March 2008 12:46 AM
Cd's as wind generator things Alternative Energy 16 13th June 2007 06:31 PM
Wind turbine blade designs Salaki Alternative Energy 31 17th May 2007 08:03 AM
Wind energy to electric energy Vaibhav Birit General Electronics Chat 192 28th July 2005 01:58 PM
Making a wind sensor xcfisher Electronic Projects Design/Ideas/Reviews 13 12th November 2003 05:36 PM
