Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 22nd October 2007, 09:40 PM   (permalink)
diddy5584 is on a distinguished road
Default help with solar power source
I am looking to power a low energy use gps device haven't decided on a certain type of device but need this to be in a small package and able to run for possibly 4 years without an alternative power source. This will be in a commercial application and needs to be no more that 5 inches by 5 inches by 3 inches including all gps and solar connectivity. the gps needs to run for approximatly 15 hrs a day and be able to run on cloudy days as well. I think it can be done using a small solar source like one found in a garden light but am extremely new to this and wondered if it is just me being a novice or of I am correct in my assumptions of it be possible.
the gps I think will work is at this link:
http://www.navsys.com/Products/tracktag.htm
this may be the system i am using just need to do somemore research to find out if it will give me the locations on a scale i need
Thanks for all your help and remember I am a newbie and not very up to date on what is out there due to just starting project
diddy5584 is offline   Reply With Quote
Old 23rd October 2007, 08:30 AM   (permalink)
Super Moderator
The solar panel in garden lights provides hardly any power at all, I would suggest you need a MUCH larger (and better quality) panel. GPS units are also fairly power hungry.
You really need to do some experiments, run tests on a solar panel under varying conditions, bearing in mind you're not going to get anywhere near the optimistic claimed ratings. Also get the electronics built and tested, and check on it's power requirements.
Old 24th October 2007, 12:58 AM   (permalink)
Experienced Member
Sceadwian is a glorious beacon of lightSceadwian is a glorious beacon of lightSceadwian is a glorious beacon of lightSceadwian is a glorious beacon of light
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
Nigel, the module he referenced says it will last 4 months on a 120mah hour battery. A solar cell might cut it with an efficient charging system using ultra capacitors. I'm not willing to do the math on it right now though. I'm asuming this is on the low reading setting (one reading every 24 hours)
The OP needs to do as Nigel suggested, determine his reading rate, set up the module and measure it's current usage. Also knowing the environemental risks helps (say a leaf falls on it and you lose power)
Curiosity killed the cat; That's why they have nine lives.
Old 28th October 2007, 12:21 AM   (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Send a message via Skype™ to Krumlink
what voltage are you looking for? I would get solar cells if it has low voltage (like 1.5). Solar cells output .5V at around 1 amp.
http://www.goldmine-elec-products.co....asp?dept=1174
MechTronics
Krumlink is offline   Reply With Quote
Old 28th October 2007, 02:51 AM   (permalink)
Experienced Member
Super_voip is on a distinguished road
That gps/battery comination lasts for 2years @ 1 reading pre hour. If you doubled the battery capacity it should last for 4 years.
Super_voip is offline   Reply With Quote
USB Power hack with DC/DC Converter - am I crazy? chconnor Electronic Projects Design/Ideas/Reviews 14 8th March 2008 09:12 PM
Push Button On/Off power to PIC eblc1388 Micro Controllers 8 17th February 2006 01:31 PM
Ultra low power power supply steevke Electronic Projects Design/Ideas/Reviews 1 3rd February 2006 03:46 AM
Powering a mini R/C car by solar power Cyclone Electronic Projects Design/Ideas/Reviews 16 14th February 2004 06:00 AM
12v mobile small power source lazynok Electronic Projects Design/Ideas/Reviews 1 9th June 2003 08:05 PM
