Experienced Member
...but not exactly on topic either. I thought it was kind of cute. I'm not sure if the capacity of these batteries makes it an apples to apples comparison.
http://www.metacafe.com/watch/824477...ull_be_amazed/ |
Experienced Member
What!?!
I opened one of those 6v up once and found 4 "D" cells. Why would you use 32 smaller batterys? Would it lower the resistance and allow for more current draw?
This message transmitted on 100% recycled electrons
Experienced Member
probably more capacity. there is less wasted space. But hey, I never actually thought about lantern batteries prior to this.
Experienced Member
That says "heavy duty" on the outside. That means they're the crappy carbon batteries, not alkalines. Low overall capacity, and their internal resistance is so high that many devices won't work on them even when the batteries are fresh.
I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
Experienced Member
It's a hoax. Lantern batteries contain 4 long batteries (f cells?) and are wired together with welded on metal strips. I'm not sure that many AA batteries would even fit in a lantern battery but if they did, they would be connected together somehow.
Mike. |
Experienced Member
I thought what I'd do was I'd pretend I was one of those deaf-mutes. Last edited by Oznog; 19th September 2007 at 05:57 AM. |
Super Moderator
Experienced Member
Wonder why somebody would make such a video in the first place? There was no way for those AA to produce 6 volts and just spill out like that. The outer case of each was bare, none were wired or welded, and all oriented in the same direction. Guess it would fool some people, but why? Suppose it sort of like releasing a computer virus. Wonder if that brand 6 volt battery even exists, or if he made his own label for this video project.
I've been off the throw away batteries for years now, just an occasional 9 volt for the alarm clock, and caller-ID box. |
Experienced Member
Does anyone here have a 6v lantern battery that is dead or weak they would like to open and show us? What is normally in one?
Like I have said before, I got a damaged Duracell 6v once for free where I worked at the time, and opened it and found 4 "D" cell Duracell batterys inside. They even had the label on them. I have a cheap, plastic cased 6v on my bench that I use for a power supply. I hate to kill it and open it up before its dead, but I am curious.
Experienced Member
Experienced Member
Harvey, I'm sure the video is completly geniune. The top and bottom of the case were likley spring steel contacts routed in such a way as to produce a 4 series 8 parallel configuration which would give you a nominal 8 volts. Under any kind of load it's probably pretty close to 6 for most of it's discharge curve.
The local dollar store sells cheap alkaline cell 6 packs for a buck though. For 5 bucks that'd be 30 cells and they'd be real alkaline's.
Curiosity killed the cat; That's why they have nine lives.
Moderator
It is a hoax. Lookie here!
http://message.snopes.com/showthread.php?p=327714 |
Experienced Member
