| Experienced Member | I'm totally skeptical that this can be made into a practical solution. I doubt the efficiency is very high. Unless there is a cheap source of producing RF energy it's probably a complete lose. http://www.post-gazette.com/pg/07252/815920-85.stm |
| Experienced Member | Wonder what frequency and power level they used. Since the origional research was in medical, wouldn't think the power levels very high. But then again chemo-theropy uses near-lethal poisons, radiation theropy, and radical surgery, so guess side-effects of the treatments in cancer research isn't of great concern. Have to do some searching on this. Tend to go with the balanced equation on this stuff, the output equals the input. Since there are always losses and waste in these processes, usually not worth the effort. But here in Florida, we have lots of ocean, and lots of sunlight, both free. So if a good volume is produced, might be worthwile to pursue. |
| Experienced Member | The process has the classic problem in that Oxygen and Hydrogen are not generated seperately. It's not a stable fuel. In Florida as anywhere else, if you can generate RF, it normally comes from an electrical supply. Might as well sell it on the grid. |
| Moderator | He powered a Stirling engine, congrats. But if the RF transmitter uses 100Watts and the stirling only generates about 10watts, it is a total waste. Cool topic though.
__________________ MechTronics |
| Experienced Member | Quote:
| Moderator | Does this one create 90 watts? That is quite alot if it is.
| Experienced Member | Yes, yes it does. :P On a serious note, I hope this guy doesn't go off on one with his burning water fueled by the funding, but instead continues his Cancer research. |
What are the products of this 'combustion'? I think that what's being witnessed is the ionisation of salt water in an RF field, that would make far more sense and it's what I'll believe due to the lack of anyhing else to suggest otherwise. The test tube probably glows bright greenish yellow - like a sodium street light, the energy out (heat and light) is exactly the same as the energy in (RF). | |
| Experienced Member | True, although I was only talking about the RF absorbed by the tube. |
| Experienced Member | Its very easy to figure the power in and out, and the reason its not mentioned ( like so many other scams and pipe dreams) is that of course it uses more than it produces. People must think all radio waves are low energy. Sam |
| Experienced Member | At the turn of the 20th century, some yahoo got the bright idea to run a clock off a battery. He then connected a small generator (design?) to the clock mechanism, which he used to recharge the battery. Yes. Really. He convinced Congress to advance him a $50,000 loan to investigate the design further. Or so I read as a kid. Considering the debacle Congress agreed to fund in Iraq, I find this quite plausible. kenjj
__________________ All my pencils *used* to have erasers! |
| Experienced Member | Patents of that nature (over unity) aren't allowed to be applied for anymore. It's one of the few things (only?) they specifically disallow. If you can sucker some private sector investor to put up money though, it's all about marketing, most investors don't look so close at what they're investing in to smell these kinds of frauds.
__________________ Curiosity killed the cat; That's why they have nine lives. |
Second is there's no RF freq that is transparent to water-saturated carbon-based tissue so that it will penetrate without major heating and suddenly generate lethal heat when it hits tiny amounts of gold or carbon. Basically he's promising "magic" here but we already know a lot about what RF will do.
| | (permalink) | |||
| RF reader for water meter | Super_voip | General Electronics Chat | 4 | 19th July 2007 06:45 PM |
| Need Low Volume Water Pump | Noggin | General Electronics Chat | 27 | 26th June 2007 04:32 AM |
| water overflow holes | atntias | Math and Physics | 3 | 25th June 2007 08:46 PM |
| submerging a pressure sensor under water? | AndyWatson | Electronic Projects Design/Ideas/Reviews | 14 | 26th October 2006 09:37 AM |
| measuring the resistance of water | kleen | Electronic Projects Design/Ideas/Reviews | 20 | 6th August 2004 03:50 PM |
