| Experienced Member | This is in Initial Stages, But it Works. Writeup includes Pictures and a Working Video Also. http://www3.telus.net/chemelec/Proje...ill/Wind-2.htm Gary
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec |
| Moderator | I like it. Please keep us updated as you make progress.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
| Experienced Member | Neat! It is quite different from other vertical windmills that I've seen. The "vanes" appear to flop around a little in the video due to turbulence. Does it make much noise? Your site states that it is best suited for light winds. How would it perform in high winds? Are you planning on any "shutdown" features for stormy weather?
__________________ --- The days of the digital watch are numbered. --- |
| Experienced Member | Quote:
For One, No Outside Frame as shown. This FIRST TEST: Not Much noise, But only a Light Wind Today on this test. I have some Ideas, for Strong Winds, But Need a Metal Frame First. Occassionally we get Gusts to 100 MPH, so Yes this is a Concern. (They just made a Movie here in town, and Right in the Middle of it we had a 10 Minute Storm, 100 MPH Winds. Pictures in my General Pictures on Home Page) However that will Probably be Next Year. This is a TINY TOWN, Pop 485, no real industry. I Need to go to Vancouver to get the Custom Made Framing I need. Its a 4 Hours Drive for me to get there and the Time required to have the parts Fabricated. Probably in September. My Next step is to put in all the panals and Add a Generator to it. Than TESTS on it for power out. If the WIND BLOWS, When I need it.
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | |
| Experienced Member | Hiya Gary, Good to see ya got the wind genny bug Give that idea a go mate and hopefully it will workout for you, not only is it easy to build and easy to repair but it costs hardly nothing to make. I'd hate to see you make that huge genny only to see it flying over the north pole when a strong storm hits. Cheers Bryan
__________________ " The only way to avoid human error is to avoid the use of humans" |
A Few Things that Puzzles Me is in the write-up Drawing, it says: "A Powerful Windmill can be made with 3 Sheets of 3M Corrugated Iron Per Vane. (A 18HP in a 15KM Breeze.) First, What is "Corrugated Iron"? Sheet Steel or Galvanized Steel I understand, but Not "Corrugated". Second, What is 3M? (3 Meters?) If so, that One HUGE Blade. Third, Looking at the Pictures, the vanes appear to have bends at BOTH Edges. However in the Drawings, it only shows putting a bend at one Edge. WHICH IS CORRECT? And Lastly, I can Call Australia for FREE as long as its a "Land Based" Phone Number. So would you consider Emailing me your phone number and we can discuss this a bit better. (I'm in BC Canada, a 15 Hour Time Difference.) Take care.....Gary
| Experienced Member | i don't think a peltier cooler will work, they draw alot of energy and will not cool a whole room. apart from that, it's a great project!
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. |
But the way these devices work, there More Efficient for cooling from 25 or 30 degees down to 20 degrees, than they are in trying to get down to 5 degrees. The Really Cold temperatures are difficult. Also Water cooling in a house is easier than a cooler in a car. And Besides that I already have lots of them and its something to play with.
| Experienced Member | another prob with peltiers is that if the air outside is too hot, it will not get to the temperature you were hoping for. other than that, it sounds like a great project! good luck!
| | (permalink) | |||||
( ) ( ) to give you the idea of the profile. Quote:
Cheers Bryan
__________________ " The only way to avoid human error is to avoid the use of humans" | |||||
| Experienced Member | peltiers can be stacked to increase the heat pump effect although it is morer of a pyramid. You're right they are not very efficient but I did see a picture of an airconditioner using them (built by US Army) in "Modern Thermoelectrics" published in the early 80's. Also some power gensets (again US Army), but it was the radioactive(nuclear) pacemakers using them that showed where they can have great use. |
| Experienced Member | I have done a Re-Design of this windmill. Same Principal, But MUCH Simpler design and Better. Unfortunately I Can't make a Proto of this new one using wood. And I only had a Small piece of metal to Test my new Idea. It WORKS Great. When I get to Vancouver (Probably in September) I will be getting the pieces I need to build one. When its Built, I will post it on my site. As to the Present Proto, It does generate Reasonable power. But Remember that Power on this design is mainly a Function of Wind Speed, Surface Area and Span. So within Reason, Bigger is Better. EDIT, NEED A GENERATOR: Not Sure Whats Available in Most other countries, But in Canada and probably the USA, All newer cars have Electric Fan Motors to Cool the Radiator. HERE in Canada, these are all Permanent Magnet Motors. They make a NICE MAGNETO, with No alternations needed. Drive them at a Reasonable Speed from a Windmill or Water Wheel and They Produce a good amount of Power. The Ones I have produce a DC OUTPUT of about 10 volts or so and reasonable current. And you could run Multiples in Series or Parallel for higher Voltage or Current. Besides you can pick them up at Auto Wreckers QUITE CHEAP. Enjoy....Gary
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec Last edited by chemelec; 31st July 2007 at 11:38 PM. |
| New Member | This looks like a great project! Keep us all posted on the progress! Its nice to see people looking for alternative energy sources.
__________________ My Speaker System Website |
| Experienced Member | Update, Slow but Steady Progress. I have now contracted two companies to make some of the pieces I need. One is to get 100 pieces of: ".162 inch diameter, Straightened pieces of Spring steel wires and cut to 24 inch lengths". (Aproximate Cost $160.00) The other is for some custom pieces made of .080 sheet aluminum for the special framework I have designed. (Estimated Cost $350.00) NOT a cheap project, especially for smaller quantities of Custom made stuff. My plan is to pick these up in Vancouver in early September. Than I will need to manufacture some other pieces before I can put it all together. Take care..... Gary
| Experienced Member | |
| How do wind a transformer | FusionITR | General Electronics Chat | 16 | 31st March 2008 12:46 AM |
| Wind Generator - Star Delta Controller | simoin | Alternative Energy | 39 | 15th June 2007 01:24 PM |
| Wind turbine blade designs | Salaki | Alternative Energy | 31 | 17th May 2007 08:03 AM |
| Good Wind power website | fzn10 | Alternative Energy | 4 | 18th July 2006 08:02 PM |
| Making a wind sensor | xcfisher | Electronic Projects Design/Ideas/Reviews | 13 | 12th November 2003 05:36 PM |
