Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 19th July 2007, 05:56 PM   (permalink)
Experienced Member
TheVictim has a spectacular aura about
Send a message via AIM to TheVictim
Default Design suggestions for Stirling generator
I'm trying to make a small Stirling generator to directly produce electrical power. Instead of a piston I figure a flexible diaphram would work better since there wouldn't be any pressure loss from an imperfect seal. The temperature on the hot side wouldn't be very high, not above 140f, so even latex would work. The cool side is going to be anywhere from just above freezing to room temp (provided by a small earthenware evaporator) so the differential isn't going to be that much, which is another reason for the diaphram so the generator can operate at very small differentials in temperature.
My question is should I have the actuator that is attached to the diaphram turn a reciprocating wheel to generate electricity, or should I just mount the magnets on the actuator (which also triggers the cold side return valve) and have its motion within the generator coils produce power? Which would be more efficient? I'm siding toward the rotational model.
TheVictim is offline   Reply With Quote
Old 21st July 2007, 02:11 AM   (permalink)
Experienced Member
Oznog is just really niceOznog is just really niceOznog is just really nice
Send a message via AIM to Oznog
I'm not sure how you'd use a diaphragm because the Stirling engine piston's action exposes the warmed/expanded air to the cooling surface of the cylinder. With a diaphragm, the air will move but will remain exposed to the rubber diaphragm surface which does not have any substantial cooling effect.
Oznog is offline   Reply With Quote
Old 21st July 2007, 04:27 AM   (permalink)
Experienced Member
When the diaphram is fully extended, it will also actuate a ball valve on the cool side that will open a connection between the cool side and the hot side, at which point the diaphram will contract again, allowing the ball valve to close and the cycle to repeat.
Old 26th July 2007, 09:50 PM   (permalink)
Experienced Member
I completed the proof-of-concept experiments today, looks like a diaphram WILL work, but I am going to have to use multiple cylinders and a camshaft. I'll also have to ditch the ball valves and go with a flapper valve.
Old 27th July 2007, 03:08 AM   (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
I have 2 low temperature differential (LTD) stirling engines. Both use a polystyrene displacer to move the air between the hot and cold sides and one of them uses a rubber diaphram as the power piston.
Just found their web site.
Pommie is offline   Reply With Quote
Old 27th July 2007, 05:10 AM   (permalink)
Experienced Member
My design seems to be different than the classic Stirling engines. There will be 8 cyclinders, 4 hot side and 4 cool side. They will be in a V8 arrangement at 60 degrees to the camshaft. Each hot cylinder will be paired with a cool cylinder and linked with a duct. Airflow through the duct will be controlled by a valve flap on the hot side of the duct. The rotation of the camshaft will provide pressure on the cool side diaphram to move cool air into the hot side cylinders.
I'm not sure how much power I am going to get. I'm going to build a small model from food cans and a wire camshaft before I move on to the full sized model, which will have heat exchangers right inside the cylinders.
The eventual plan is to have the hot side heat exchangers powered by a solar collector and the cool side by an earthenware evaporator. I'm just hoping that the pump for the heat exchangers and the fan to the evaporator won't consume more power than the machine can produce. That is a long way off though. I'm going to get the small model working and then move on to some proof-of-concept experiments for the evaporator.
Hopefully I'll have a tiny generator that runs off of sunlight, air, and water!
Old 27th July 2007, 09:04 AM   (permalink)
Super Moderator
It will be interesting to see how you get on - I was under the impression that Stirling engines produce only very tiny amounts of power?. If it was a practical solution I suspect it would be commonplace by now?.
Old 27th July 2007, 09:27 AM   (permalink)
Experienced Member
Nigel,
It is commercially available. Check out Wispergen.
Old 27th July 2007, 04:38 PM   (permalink)
Experienced Member
My machine is going to have the same problem that other LTD engines have, it will be very large for the amount of power it can produce. If I can't get the small model to work well I'm not going to bother building a bigger one.
Old 27th July 2007, 07:36 PM   (permalink)
Experienced Member
Super_voip is on a distinguished road
Stirling engines are very efficient, the power they produce is dependent on the power input. I'm contemplating installing a small 3KW solar gen in my backyard.
Super_voip is offline   Reply With Quote
Old 27th July 2007, 10:01 PM   (permalink)
Super Moderator
How are you going to focus that amount of solar energy to the correct place?.
Also, is 'small' the correct term? the Wispergen link above is house boiler sized, and only 1KW - admittedly it's also a boiler, but the stirling engine and generator look to be the biggest part of the entire assembly.
Old 28th July 2007, 03:05 AM   (permalink)
Experienced Member
http://www.infiniacorp.com/applicati...ean_energy.htm is a vapourware Stirling but I have a company down the road from where I work that installs 25KW solar stirlings. The internals of the Whispergen are interesting, the Stirling for the 25KW is about the size of a oil drum(44gallon) and produces 60dB noise, heat is sored in silicon and can run for 3 days without Sun. The little 3KW one, I won't charge batteries simply sell to the grid. This should offset whatever I use at night.
Old 28th July 2007, 03:45 AM   (permalink)
Experienced Member
Looks like the flapper isn't going to be as easy as the ball valve. All I have to do to duct in air from the cool side is have the hot side diaphram lift the ball off of a tube connected to the cool side. Very simple. I like simple. Now to find a lightweight heat resistant ball of the right size.
Edit (reply to above): If I remember correctly, solar energy delivers ~ 800W per square meter, and that would be at 100% efficiency. If your Stirling SOMEHOW got 50% efficiency (that is a BEST case scenario) you would need almost 4 square meters of solar collector alone. That isn't exactly small. This isn't taking into account the cool side of the gradient. You would get much more benefit if you had something cooler than the Aussie summer air. If it is going to be in the back yard I suppose you can use an underground heat exchanger.
Old 28th July 2007, 11:36 PM   (permalink)
Experienced Member
These things are in deserts all around the world(more sunny days), if the the hot side is very hot then the cold side doesn't have to be very cold rather like the radio isotope reactors in space where the hot side isn't very as the cold side is very cold. It's the temperature difference that matters. A 3metre dish should work as that would have 7sq Metres of area, so a dish less than 3m, mounted 3m off the ground. A total height of 4.5m.
Old 9th June 2008, 11:48 AM   (permalink)
Experienced Member
arrie is on a distinguished road
Hey TheVictim.
Have you made any further advances with your idea?
arrie is online now   Reply With Quote
Advise needed for 555 timer/envelope generator design..... Learner Electronic Projects Design/Ideas/Reviews 5 21st September 2004 01:13 PM
PIC12F675 Design Suggestions - Frequency to Frequency dsfii Micro Controllers 1 23rd May 2004 05:40 PM
design of impulse generator bharani Electronic Projects Design/Ideas/Reviews 0 21st April 2004 10:23 AM
control panel design suggestions analysis bonanz Micro Controllers 0 15th October 2003 12:06 AM
Circuit design help / suggestions needed. nosliwsg Electronic Projects Design/Ideas/Reviews 10 4th August 2003 06:46 PM
