Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 9th June 2008, 09:36 PM   (permalink)
as far as your original question about where to place the magnets... it would seem that making the generator built into the sterling engine, without the extra linkage etc... would be more efficient, and also a very clever design!
i thought it was a cool idea
greaserig is offline   Reply With Quote
Old 10th June 2008, 07:25 AM   (permalink)
Hi greaserig.
I don't know if TheVictim still frequents this post, but I'm interested in the whole sterling side of things. I'm not sure how he will connect the whole lot to the diaphram, or what sort of rpm TheVictim will get from his sterling, but I do know on your genny side you need quite a bit for useful single phase power, at least 3000 to 3600 rpm, and then you need some decent magnets and coils too.
So he might still need some gearing to get it up there.
Further, running a sterling at that low temp sounds risky, what I've seen is motors running 200deg.C plus to make max use of the air inside the system, and that will give your diaphram idea the march.
So it's back to a solid material design and flywheel setup, or so I believe. The flywheel can have some particular benefits, but I agree with him, you need more that two cylinders.
Is there someone who have actually built a successful sterling on the forum? Maybe he/she can give us better pointers in this regard.
I've been toying this idea for very long, and have done some design along the lines, but buying the materials to build all is a pain, and it's going to be an expensive exercise.
arrie is offline   Reply With Quote
Advise needed for 555 timer/envelope generator design..... Learner Electronic Projects Design/Ideas/Reviews 5 21st September 2004 01:13 PM
PIC12F675 Design Suggestions - Frequency to Frequency dsfii Micro Controllers 1 23rd May 2004 05:40 PM
design of impulse generator bharani Electronic Projects Design/Ideas/Reviews 0 21st April 2004 10:23 AM
control panel design suggestions analysis bonanz Micro Controllers 0 15th October 2003 12:06 AM
Circuit design help / suggestions needed. nosliwsg Electronic Projects Design/Ideas/Reviews 10 4th August 2003 06:46 PM
