Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 15th July 2007, 01:56 PM   (permalink)
Experienced Member
kalaman is on a distinguished road
Default 1,2v to 3v dc/dc converter
i have charged one ni-mh battery and used 3v led. I'd like to make 1,2v to 3v dc/dc converter which is not include any IC. Because I couldn't find that type ICs where i live.
Actually i found a circuit and it worked nicely but it waste source when i don't connect load.
kalaman is offline   Reply With Quote
Old 15th July 2007, 03:59 PM   (permalink)
Experienced Member
That circuit is fine for powering LEDs, I don't understand why you should want anything better.
For a simpler circuit Google Joul thief.
Hero999 is online now   Reply With Quote
Old 15th July 2007, 06:20 PM   (permalink)
Experienced Member
Firstly, thanks you for help.
It works properly but I measure 60mA standby situation. It spends 60mA when i disconnect LED. Is it normal ?
By the way my English so bad. I'm sorry.
Old 15th July 2007, 07:10 PM   (permalink)
Super Moderator
Then don't disconnect the LED - and yes, I would imagine that is perfectly normal.
Old 15th July 2007, 08:27 PM   (permalink)
Experienced Member
Does the capacitro blow up when you remove the LED too?
Old 15th July 2007, 08:53 PM   (permalink)
Experienced Member
blow up = explode ?
Old 15th July 2007, 09:20 PM   (permalink)
Experienced Member
Yes, there's nothing to control the maximum output voltage from this thing so fi you're not careful the capacitor will explode as it's maximum voltage rating will be exceeded.
Old 15th July 2007, 09:38 PM   (permalink)
Experienced Member
Yes absolutely right. Because i remove the led electrolitic cap's voltage goes 11-12V.
Allright. this circuit eat 60mA from my poor battery without led. any idea alternative circuit?
thanks for replies
Old 15th July 2007, 09:47 PM   (permalink)
Super Moderator
You don't appear to be listening?, WHY ARE YOU REMOVING THE LED!!
Old 15th July 2007, 09:59 PM   (permalink)
Experienced Member
Hi Nigel. You are angry with me. I'm so sorry. But I supposed that something is wrong in my circuit. Maybe there might be an alternative circuit.
Anyway thank you.
Best regards
Old 15th July 2007, 10:03 PM   (permalink)
Super Moderator
You still haven't answered the question?.
There's nothing wrong with the circuit, just don't disconnect the LED - and why would you want to?.
Old 15th July 2007, 10:19 PM   (permalink)
Experienced Member
My electronic knowledge is a little bad. So according me any circuit spends more watts when you use load. When you remove the load every circuit's standby current decreases. But this circuit surprised me in this case.
As a result i'm wrong. I will use this circuit with solar energy and any mA will be important for me.
This was just curiosity.
I won't remove the led forever.
Best regards
Old 15th July 2007, 11:21 PM   (permalink)
Experienced Member
I haven't analysed the circuit in detail but from a quick glance:
This circuit is a flyback step up converter.
It works by suddenly interrupting the current through an inductor so the large back EMF charges a capacitor.
When you disconnect the LED the current in the inductor decays faster so the gap between the inductor being turned on and off is shorter causing it to draw more current.
Old 16th July 2007, 02:59 AM   (permalink)
Experienced Member
justDIY is a jewel in the roughjustDIY is a jewel in the rough
come on guys, lets not be too dense here
the OP talks about disconnecting the led. perhaps they mean they're turning off the led, upstream of the converter. not exactly a good solution, since it leaves the converter running.
I don't know if you're interested in making things more complex, but the TPS61040 from Texas Inst is a very small boost converter with some nice features. 28 uA quiescent current with no load and 1uA current in shutdown.
I built a flashlight based on one of these long ago, powering eight white leds (in series) off a pair of aaa batteries. My ammeter can't measure the current draw from the batteries when it is "off", it doesn't show up on the 2mA (lowest) scale.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline   Reply With Quote
Old 16th July 2007, 07:36 PM   (permalink)
HYTECH is on a distinguished road
http://www.emanator.demon.co.uk/bigclive/joule.htm
HYTECH is offline   Reply With Quote
USB - TTL Converter samltd Electronic Projects Design/Ideas/Reviews 5 7th July 2006 09:46 PM
Buck-boost dc/dc converter with a wide range Velectro General Electronics Chat 2 5th April 2006 02:01 PM
DC/DC converter jrz126 General Electronics Chat 2 6th January 2005 11:26 AM
DC/DC converter jrz126 Datasheet/Parts Requests 0 4th January 2005 06:13 PM
DC/DC Converter (Miniature Remote Control Solar Car) devonsc General Electronics Chat 167 21st December 2004 04:36 AM
