Experienced Member
Actually, I think that declining production will hurt them a lot sooner. Any company that thinks of itself as an Oil Company instead of an energy company is doomed. History is replete with failures due to short term thinking (railroads vs transportation).
Anyway, if they aren't searching out new sources of energy, they are going away soon. Instead of killing people, they would be courting them with high priced salaries, stock options, fancy labs, ... It is a fantasy to think that some little guy will figure out what heavily funded scientists and engineers with deep expertise haven't. |
Experienced Member
In every case that I have seen of such claims of efficiency greater than 100% there is always some energy that has been snuck in to the system that has not been accounted for that would make the overall calculations show less than 100% efficiency, as it should be according to the laws of thermodynamics. So, show me in forms of chemical equations that the "catalyst" used and the electrodes used are not contributing to the excess energy somehow in an irreversible chemical reaction and you might make it an appealing science project. I'm not holding my breath though. |
Experienced Member
Broz,
I agree with what you're saying, the energy has to come from somewhere which makes perfect common sense. The energy in the reaction on the website probably does come from either the electrodes or the 'catalyst'. The only issue I do have is that the reversibility of a reaction has nothing to do which it. The reaction that occurs when you burn hydrogen is completely reversible by electrolysis (as I'm sure you're aware). I think what you mean by reversibility in this case is that for a chemical to be acting as a catalyst should not be consumed, if it's involved in a chemical reaction that converts it from one form to another the reverse should be happening simultaneously, at exactly the same rate. |
I'am doing more research on phase locked loops after your post Francois, It's very interesting,Here is a excellent link explaining it for others that are interested.
http://www.uoguelph.ca/~antoon/gadgets/pll/pll.html |
of ideas was a good thing except when someone in the discusion thinks he can make himself feel better by putting another belief system down. There is an old saying "if you have nothing nice to say DONT say anything. I understand there is a long way to go and it is frustrating at times but If we help one another understand what we have learned on a personal level and what our aspirations are then we CAN find academic purity in the end. And after all is it so hard to believe that a frequency can upset the covalence shell that one thing becomes another. |
I have recently started researching making Brown's gas and I think that the idea of separating hydrogen and oxygen using pulsed DC just might work more efficiently. From what I had read Stan was using a voltage of around 1.0 - 1.5 Kv DC at 20 Khz and this could be depended on the length of his plates (which I believe were stainless 416 grade) pipe on the outside and rods in the center. Also the distance between the plates I would think would effect the frequency.
73's Timbo |
Super Moderator
No one yet has managed to get these scams to work yet, perhaps you might be the first? - but the majority here are convinced it can't possibly work. |
Experienced Member
1-1.5Kv? You'd fry yourself it was actually 1.2V -2V max with I believe 1.2 being the optimum voltage, and the frequency varied all the time depending on the type of water, how much was in the container and the additives in it, thats why so many adjustments I'm with the " it MIGHT work" group, however there is NO way you can get enough gas to poweran ICE(internal combustion engine) without MANY such setups running in parallel, and the current being drawn by that many would be more than the alternator in the car could supply, let alone supply enough and still power all the other things in the car. Your talking around 10A minimum per circuit, 20A possibly depending on how you work it and possibly even more, multiply that by the amount of "generators" you'd have to have to produce enough gas to actually power the engine with no petrol(gas for you americans) then your talking around 200Amps MINIMUM not feasible on a car. Last edited by karenhornby; Yesterday at 06:06 PM. |
Experienced Member
Yes, I agree with you 100% Karen. That is why some people only want to supplement expensive gas with inexpensive HHO. ATM, this seems to be THE biggest unknown. How many liters per min of HHO do you need for a 1.0L or bigger engine at a given RPM. Before I can contribute my numbers, I am planning to buy a programmmer, adjust the fuel curves way lean, and adjust the air/fuel mixture from 14.7/1 to something like 30/1 or 60/1. Then add in some HHO. Very complicated and time consuming procedure. Not to mention $500 for the programmer...
HHO has serious potential! |
Experienced Member
Truthiness Monkeys : Obedience, Ignorance, Fear. |
Experienced Member
ATM = At The Moment
AFAIK = As Far As I Know WRT = With Regard To WTF = Whiskey Tango Foxtrot (What the F---?) IIRC = If I Recall Correctly YMMV = Your Mileage May Vary A large collection of common (and not-so-common) Internet acronyms is available at http://www.gaarde.org/acronyms/ (first Google hit). There are others around too. HTH! Torben
Curiosity was framed. Ignorance killed the cat. Last edited by Torben; Yesterday at 08:04 PM. |
Experienced Member
I don't think any one else would have even bothered.
But you know me. I still get hit with it ? I will be saving that URL. Thanks again.
Experienced Member
Experienced Member
(permalink) | ||
Experienced Member
http://en.wikipedia.org/wiki/Stanley_Meyers Quote:
