Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 4th June 2007, 05:46 PM   (permalink)
Experienced Member
That's a good idea!
A centrifugal governer system could be used to pull the magnets out of the coils as it spins faster.
Hero999 is online now   Reply With Quote
Old 4th June 2007, 11:27 PM   (permalink)
Experienced Member
simoin is on a distinguished road
Default I want a star/delta controller
okay so these are all great idea's but the original questions remains, does anyone know how to setup a star/delta controller that is user adjustable so that the optimum change over point can be found after achieving and holding optimum point for x seconds?
see the picture below for what the magnet block looks like.
Please have a browse around of this website to see exactly what it i am doing... www.thebackshed.com
Thanks for the help thus far
simoin is offline   Reply With Quote
Old 5th June 2007, 11:38 AM   (permalink)
Super Moderator
It's easy to do, either using a micro-controller or just opamps etc. Simply measure the speed of the rotation, if it's below a certain level then select it as a high voltage connection, if it's above a certain level then select it as high current. Without a micro a simple frequency to voltage conveter feeding a comparator should be all you need?.
Old 7th June 2007, 12:11 AM   (permalink)
Experienced Member
so is the sort of op-amp you are referring too? http://en.wikipedia.org/wiki/Operational_amplifier
How would you suggest measuring the speed of shaft rotation?
Old 7th June 2007, 11:35 AM   (permalink)
Super Moderator
Yes, used as a comparator, or you could use a specific comparator chip?.
There's a frequency to voltage IC you can get (I can't remember the number off hand, but someone will probably post it shortly?) - or you can use a 555 in monostable mode.
Old 8th June 2007, 04:52 PM   (permalink)
rippersoftware is on a distinguished road
Default Tachometer circuit
Scoraig measures based on the rise of voltage from the AC generated from the 3 phases. Captures this and runs it thru a tachometer circuit.
From there, you can do what you want with the analog information. Scoraig switches heaters onto the output for load based on RPM. See the page:
http://www.scoraigwind.com/circuits/index.htm
RipperSoftware
rippersoftware is offline   Reply With Quote
Old 8th June 2007, 06:36 PM   (permalink)
Experienced Member
Thank you and welcome to the forum.
Old 10th June 2007, 04:59 PM   (permalink)
jolino is on a distinguished road
Hi Simon,
Considering all what people said, let me suggest one more simple solution in contrast with the circuit that you have posted in first place, and again, considering some cited aspects.
1. The rotation sensing is maded by viewing the wave/signal present in any point of any coil, before rectifiers. No more hall-efect sensor needed.
To make this work, the generator/battery disconnection must be made beetwen the bridge and battery.
2. I suggest 2 relays intead of one by two reasons:
a) When STAR relay is OFF -> STAR position, no battery discharge.
b) When ON / OFF relay is OFF -> generator is desconnected from bat and no bat consumption.
- So, when both relays off, just a few miliamps from battery.
3. With the KEY, you can configure:
a) The speed at wich the system switch from star to delta.
b) The speed at wich the system disconnect the generator.
c) If needed, you can have generator disconections to max and min speed.
4. You have also STAR/DELTA indication througt the Leds.
Notes:
1. Of course you need a little 78L05(+5V) to supply the PIC.
2. The software to do it, is very easy.
3. Sorry for duplicated references in the schematic.
Regards
Jolino
jolino is offline   Reply With Quote
Old 12th June 2007, 11:16 PM   (permalink)
Experienced Member
anybody else have any thoughts on the new circuit jolino ha put forward, it sounds as if it will be great. I think i can work out a 5volt power supply for it easy enough too.
Old 15th June 2007, 01:24 PM   (permalink)
Experienced Member
Klaus is on a distinguished road
Default Adjusting field current in a permagnet magnet rotor??
It appears that many respondends jumped on the bandwagon without bothering to read the links you posted, where it becomes obvious that there is NO field current to adjust with a permanent magnet rotor.
So you are right to ponder the star/delta question.
Nigel's reply gives you a good reason why bothering with that complication.
My practical suggestion is how to accomplish this:
Do the switching bit with a suitable relay.
Control the relay from a centrifugal switch.
You may salvage such a switch from any single pole squirrel cage AC motor, aka ex washing machine (not Fisher Paykel;-).
You may have to tinker with the centrifugal weigths to get the right switching time. To do this rig up the wind generator minus the blades and drive it from a suitable variable RPM source - if I had to do this I would use my lathe for the driving power.
The electronic 32 point switching module seems far too complicated for this application and I can't see why anybody would require so many switching points unless you plan to use variable geometry adjustable blades for your windmill.
Klaus
Klaus is offline   Reply With Quote
Xbox 360 Tilt Controller adamthole Electronic Projects Design/Ideas/Reviews 0 20th January 2007 05:24 PM
closed loop controller that receives set point updates TXRX usacanbiteme Electronic Projects Design/Ideas/Reviews 5 28th September 2005 09:02 PM
NES controller help Halogrunt1234 Electronic Projects Design/Ideas/Reviews 2 22nd July 2005 02:07 PM
Help With Temperature Controller bryan Electronic Projects Design/Ideas/Reviews 4 30th June 2003 12:18 PM
Monitoring PIns of controller at the same time waqar Micro Controllers 9 12th May 2003 10:12 AM
