Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 1st June 2007, 11:58 AM   (permalink)
Experienced Member
simoin is on a distinguished road
you've nailed it Nigel, that is exactly what i want to be doing, it is just coming up with a circuit that is on the market or indeed deigning something that can do this for me.... Any idea's there? I am willing to contribute towards costs etc, I would do it but simply do not have the experience necessary.
I do not believe the field is editable, but indeed I do not really know, what you were looking at in the last picture is basically it, there is that and the magnets on the outside, that's about as technical as this generator gets...
simoin is offline   Reply With Quote
Old 1st June 2007, 12:53 PM   (permalink)
Super Moderator
For a start I would suggest making accurate measurements on what the generator actually provides in the different configurations, at different speeds. Make sure it's viable, and find what speed is the optimum changeover point.
Old 1st June 2007, 01:00 PM   (permalink)
Experienced Member
i will do my best to make mesurements but assuming it did make a reasonable difference what then. I would like to be able to adjust the changeover point to set it at the optimum after the control board is in place perhaps with a trim pot controller or something...
Old 1st June 2007, 04:02 PM   (permalink)
Super Moderator
Depending how you design it you could certainly use a pot to adjust the switching point, or you could do it in software if you use a micro-controller for the job.
Old 1st June 2007, 08:42 PM   (permalink)
Experienced Member
Originally Posted by Nigel Goodwin
I certainly wouldn't agree that you need a variable field current - not for what you're trying to do - varying the field current wastes the mechanical power captured from the wind. Presumably you're looking to gain the maximum amount of power from it?.
The field current doesn't take much power and it's required anyway providing it doesn't have a permanent magnet rotor. Therefore it makes a lot of sense to reduce it at high speeds so the voltage doesn't exceed the battery's maximum and increasing it at lower speeds will make the alternator more efficient since it will be producing power that would otherwise be wasted.
Old 1st June 2007, 08:59 PM   (permalink)
Super Moderator
I would disagree, the field current takes a fair amount of power - which you can't afford to waste in something like this - any power going to the field coil isn't going in to the battery!. Using a permanent magnet means you get maximum power all the time - when the battery is fully charged you dump the excess to a dummy load. This may sound wasteful, but it's no different to the field coil - where you're still wasting wind energy once it's fully charged.
Old 1st June 2007, 10:30 PM   (permalink)
Experienced Member
Why is it that they use field wound machine in cars then?
To get an output at different speeds; isn't that what we want?
Also note that I'm saying you should keep the field carrying current continuously (like I said before) there come a point when it isn't profitable to keep it powered and there should be a switch to disable it.
Old 2nd June 2007, 01:20 AM   (permalink)
Experienced Member
HarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to all
In a car, the alternator is spinning fast enough to be self powered when the engine is idling. Once the car is started, you don't even need the battery.
The wind doesn't blow constantly or consistantly, so you need to store what you can. Field windings instead of permanent magnets would use power, and you would have to wait and measure RPMs until the speed came up enough to produce more energy then the field would consume. So, yes the magnets put drag on the rotor, but that's another design issue.
My wind power experience has gotten past stepper motors and LEDs (no batteries yet). Tomorrow should be our first tropical storm through central Florida, so get to see some bright flashing lights, or maybe searching the yard for pieces...
HarveyH42 is online now   Reply With Quote
Old 2nd June 2007, 03:58 AM   (permalink)
Experienced Member
williB is on a distinguished road
There is no field winding on a F&P alt/motor.
it is a permenent magnet three phase motor ,which makes it a very nice three phase windturbine alternator
williB is offline   Reply With Quote
Old 2nd June 2007, 04:45 AM   (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
Wouldn't the most efficient system be a star configuration with a SMPS to convert to 12V. The diode losses at high voltage/low current are reduced considerably and SMPS are very efficient.
Pommie is online now   Reply With Quote
Old 2nd June 2007, 08:27 AM   (permalink)
Super Moderator
Because you have energy to burn, and it's a VERY easy and effectvie way to control the amount of energy output.
No, we're wanting the MAXIMUM possible energy from the wind.
????? - no field current, no output (well hardly any), what good is that?. And on the other hand, you need maximum field current when the alternator is spinning slowly - energy you can't afford - particularly when it gives no advantages for a wind generator.
Old 2nd June 2007, 02:05 PM   (permalink)
Experienced Member
Well, the savonius didn't make it through the night, top section came off. Will re-glue it when it dries off. The propeller version is still going strong. Funny thing, the storm we had last night wasn't Tropical Storm Barry, late this afternoon I'm guessing.
Old 3rd June 2007, 11:57 PM   (permalink)
Experienced Member
okay so I have my 3 phase Permanent Magnet generator, now how do I switch from star to delta when the wind kicks right up?
Pommie - stupid question for you, what do SMPS do? I was just going to rectify it to 12volt using 50Amp car rectifiers. I have a diagram for there hookup at home somewhere.
Sorry to hear your savonius did not last through the start of the storm.
I have also talked to Ed from: www.windstuffnow.com/main - who says:
The controller I used was from design specialists as you posted on the alternative energy site. I don't believe he is building them or any other kits right now. Really to bad for us, they worked great as well did his tack jr. I don't know of any thing out their comparable to it.
So this means no one has a product like this and for some rising entrepunear that there would be a market for a product out there... I think we have also established that a field current generator thing is not going to happen as this is a PMG device...
Old 4th June 2007, 05:17 AM   (permalink)
Experienced Member
The savonius rotor was more of a toy, first one I threw together to see how steady and how big (wasn't big enough). Will give it another try sometime.
Switching the winding configuration doesn't seem that bad. Might be able to measure the output voltage, and switch when it's much higher then what is needed to charge the battery. Just need to determine at what point you will still get more then 12 volts, when you go to the higher current configuration.
Old 4th June 2007, 05:20 PM   (permalink)
Experienced Member
JTECH is on a distinguished road
Look at how an automovtive regulator works.
It adjusts the DC rotor current to keep the output voltage the same at different engine speeds. At high speeds the rotor current is reduced lower speeds the current is increased.
Switching from star to delta can be useful for varying the voltage but it isn't as effective as varying the rotor field current.
Hi folks! As far as I can understand about wind turbines/generators, is that usually the field cannot be adjusted electrically, because it consists of permanent magnets. One should look at a mechanical means of adjusting the air gap between the magnets and the stator, i.e. reducing the gap proportionally as the speed increases in order to get the most out of the available wind. At low speeds, a bigger air gap means less "cogging" and the machine can speed up easier. Come on, let's hear from the mechanical-inclined people on this forum!
Regards all.
JTECH is offline   Reply With Quote
Xbox 360 Tilt Controller adamthole Electronic Projects Design/Ideas/Reviews 0 20th January 2007 05:24 PM
closed loop controller that receives set point updates TXRX usacanbiteme Electronic Projects Design/Ideas/Reviews 5 28th September 2005 09:02 PM
NES controller help Halogrunt1234 Electronic Projects Design/Ideas/Reviews 2 22nd July 2005 02:07 PM
Help With Temperature Controller bryan Electronic Projects Design/Ideas/Reviews 4 30th June 2003 12:18 PM
Monitoring PIns of controller at the same time waqar Micro Controllers 9 12th May 2003 10:12 AM
