Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 30th April 2007, 05:35 PM   (permalink)
Experienced Member
Salaki is on a distinguished road
Send a message via MSN to Salaki
Exclamation Wind turbine blade designs
anyone have an idea for how i could make a blade for a savonius wind turbine as effective as possible? the wind turbine will be in this sizehttp://www.re-energy.ca/pdf/wind-turbine.pdf
Salaki is offline   Reply With Quote
Old 30th April 2007, 08:22 PM   (permalink)
Experienced Member
Papabravo is a glorious beacon of lightPapabravo is a glorious beacon of lightPapabravo is a glorious beacon of lightPapabravo is a glorious beacon of light
As any sailboat racer will tell you running downwind is the slowest point of sailing. Beating to windward is the next best. To really fly you need to be on a beam reach. So make a device that is always on a beam reach and the world will beat a path to your door...so to speak.
Papabravo is offline   Reply With Quote
Old 30th April 2007, 09:36 PM   (permalink)
Experienced Member
w00t?!?!?! what do you mean by this?? im just 13 years old i dont get it lol
Old 1st May 2007, 01:32 PM   (permalink)
Experienced Member
So you're 13, if you can design a wind generator you can see the similarity between a sail with the wind behind the boat running downwind and the half cylinder of a savonius vertical wind turbine. It would have taken you a few clicks to google the rudiments of sailing. Realizing that the static force on a surface pales in comparison to the lift generated when a fluid flows over the same surface. You might be trying to solve the wrong problem.
Beam Reach - A point of sailing where the wind is perpendicular to the boat and the sail is trimed to generate the maximum amount of lift. The boat proceeds throught the water at it's maximum speed.
Old 1st May 2007, 05:11 PM   (permalink)
Experienced Member
philba is just really nicephilba is just really nicephilba is just really nice
13? great to have you here - maybe there is hope for the next generation.
seriously, as the document says, the savonius design operates on a drag principle while the blade based turbines use aerodynamic lift. You would need to minimize the drag of the one side and maximize the drag of the other side. This is the same effect as a downwind run. I could see how some one could measure the drag of different designs and then pick the one with the greatest differential.
By the way, I would alter the savonius design a bit by seperating the generator from the blade section so you could try different blade designs easily.
there are other vertical designs that are more efficient because they use lift. like:
http://www.newenergy.com.cn/english/...mill/index.htm
http://www.greenwindmill.com/
and one other that i couldn't find a link to but it uses curved blades that bow outward and is certainly the most gracefull looking.
philba is offline   Reply With Quote
Old 6th May 2007, 01:15 PM   (permalink)
Experienced Member
how could i seperate the generator from the blade???? please tell me =) I know what you mean but I can't think of a way to seperate it from the blade.
Old 6th May 2007, 01:24 PM   (permalink)
Experienced Member
and i just have 2 weeks on me more to get everything done for the science-fair
Old 6th May 2007, 06:36 PM   (permalink)
Experienced Member
by seperate, I meant to allow you to easily replace the blades. You could use a simple coupling like this
Old 10th May 2007, 11:21 PM   (permalink)
Experienced Member
john1 is a jewel in the roughjohn1 is a jewel in the rough
Hi Salaki,
The Savonius style of rotor is (i think) inherently inefficient.
The only way to improve the wind action that i can see,
is to mask or shield the wind from the half that is detracting.
This could concievably be done by using a tail which would place
such a shield across the half that detracts.
Since my explanation of this concept is poor,
i will try to explain it another way.
The savonious style of rotor has one side moving into the wind.
This side could be shielded by a movable part with a tail.
The movable part with a tail would be positioned by the wind,
and would sheild the section of the savonius rotor which
moves into the wind.
That explanation is not much better.
But it will have to do.
I can see no way to improve the efficiency of a savonius style
rotor very far, this suggestion of adding a separate part to act
as a sort of wind-guide or shield should make a big difference,
even though it does not address the efficiency of the rotor
but changes the way the wind blows upon it.
Best of luck with your project,
and let us know how you get on.
John
john1 is offline   Reply With Quote
Old 12th May 2007, 03:35 AM   (permalink)
Experienced Member
williB is on a distinguished road
these are blades with lift , not drag.
i can cut one in a night , few hours , then epoxy the segments together
they are surprisingly rigid, being that they are made of foam
the alternator is three phase with 16 poles 12 coils and can put out 170 watts , with larger blades .
williB is offline   Reply With Quote
Old 12th May 2007, 04:53 AM   (permalink)
Experienced Member
Sceadwian is a glorious beacon of lightSceadwian is a glorious beacon of lightSceadwian is a glorious beacon of lightSceadwian is a glorious beacon of light
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
Any object which atempts to restrict/harness energy like wind has a 'drag' on it.
Curiosity killed the cat; That's why they have nine lives.
Old 12th May 2007, 03:39 PM   (permalink)
Experienced Member
Yeah , but the lift/drag ratio is greater with these blades than a ' drag' type rotor
Old 12th May 2007, 11:23 PM   (permalink)
Experienced Member
things is on a distinguished road
i just want to ask what the problem is here. i have made a HAWT (horizontal axis wind turbine) and was wondering why i only get about 2 volts out of a large dc motor when i spin the blades. also i only get voltage when i spin the blades, not when they are spinning without help. do i have the wrong kind of motor. what do you suggest?
thankyou
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline   Reply With Quote
Old 12th May 2007, 11:34 PM   (permalink)
Experienced Member
Are you driving the motor directly? Motors won't generate any real amount of electricitiy until they hit their rated RPM.
Old 13th May 2007, 02:29 AM   (permalink)
Experienced Member
thankyou
what kind of motor is it? PMDC permenent magnet dc ?
need help with building a wind turbine Salaki Electronic Projects Design/Ideas/Reviews 41 14th May 2007 09:04 PM
Savonius wind generator blade designs, help :P Salaki Electronic Projects Design/Ideas/Reviews 3 1st May 2007 06:00 AM
Model Gas Turbine ECU Barry Micro Controllers 16 22nd May 2006 02:04 PM
Making a wind sensor xcfisher Electronic Projects Design/Ideas/Reviews 13 12th November 2003 05:36 PM
