Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 13th May 2007, 09:23 AM   (permalink)
Experienced Member
things is on a distinguished road
i think it would be pmdc. it was out of a 24 volt electric scooter and is very heavy. it also has two wires out red and black.
thanks
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline   Reply With Quote
Old 13th May 2007, 11:42 AM   (permalink)
Experienced Member
williB is on a distinguished road
Thats the problem , 24 Volts ...
at what RPM ?
a 90 V PMDC treadmill motor makes a much better wind turbine generator, because the RPMs needed to produce power is a lot less.
hence to start charging a 12Volt battery ,the RPMs needed are alot less than if it was a 24V motor.
you could allways boost the voltage .
you would need a PIC controller with PWM ,a FET , an inductor and a fast diode
what you do is pulse the inductor with the fet and the generator in one loop ,when the inductor is still releasing energy and the FET is off the current has no where to go , so you place the diode above the drain (between the inductor and the fet) pointing twards your battery.
In the attached ckt..
M1 M3 and R2 are optional , as is the Cap,
your motor/generator would go where the three phase Alternator and the diode bridge is.
williB is offline   Reply With Quote
Old 13th May 2007, 06:27 PM   (permalink)
Experienced Member
Salaki is on a distinguished road
Send a message via MSN to Salaki
my wind turbine doesn't light up the lightbulb =( i did exactly as it said on the website but the lightbulb still won't light up... It's a 6,5 watt lightbulb do I need a different one??? Or doesn't it work with 4 magnets spinning above 4 coils of wire??
Salaki is offline   Reply With Quote
Old 13th May 2007, 07:16 PM   (permalink)
Experienced Member
could you describe your setup a little more ?
particulary your coils
four mags and four coils is not three phase , or single phase
Old 13th May 2007, 07:42 PM   (permalink)
Experienced Member
Sceadwian is just really niceSceadwian is just really niceSceadwian is just really nice
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
Pictures would be incredibly helpful at this point.
Curiosity killed the cat; That's why they have nine lives.
Old 14th May 2007, 06:32 AM   (permalink)
Experienced Member
try an LED. if that doesn't work post some pic's so we can see what you have done
Old 14th May 2007, 01:39 PM   (permalink)
Experienced Member
how do i post pictures?
Old 14th May 2007, 05:46 PM   (permalink)
Experienced Member
Attachment 12848
Attachment 12849
Attachment 12850
Attachment 12851
Attachment 12852
I'm using a 2,5V lightbulb that was the lowest V I could find.
Old 14th May 2007, 09:05 PM   (permalink)
Experienced Member
it's 200 turns of wire on each coil
Old 16th May 2007, 09:45 AM   (permalink)
Experienced Member
bryan1 is just really nicebryan1 is just really nicebryan1 is just really nice
Invalid Attachment specified. If you followed a valid link, please notify the administrator
Thats the message I get when I click on any of your links. If your posting pictures either jpg,gif,png etc are accepted but whatever you tried to upload the board didnt recoginise it.
Anway I read that .pdf and would be surprised if it would light an led at its full rate. An old stepper motor can be used for a small wind genny turbine and checkout this link http://www.thebackshed.com/windmill/assemblyMini1.asp
Glenn gives all the details on making it and my sticky has a heap of links to wind genny sites all ya need to do is read it.
Cheers Bryan
bryan1 is offline   Reply With Quote
Old 16th May 2007, 03:50 PM   (permalink)
Experienced Member
don't have time to build that one...
Old 16th May 2007, 03:51 PM   (permalink)
Experienced Member
impossible for me to get all the materials and build it altogheter and make my poster and stuff within 4 days
Old 16th May 2007, 03:53 PM   (permalink)
Experienced Member
i took the pictures with my web cam XD
Old 16th May 2007, 04:07 PM   (permalink)
Experienced Member
john1 is on a distinguished road
Ah pictures.
Perhaps you could post some here ... ?
John
john1 is offline   Reply With Quote
Old 16th May 2007, 08:18 PM   (permalink)
Experienced Member
There is an edit button.
There's no need to make four posts when one would have done fine!
Your knob doesn't get bigger with every post you make you know.
need help with building a wind turbine Salaki Electronic Projects Design/Ideas/Reviews 41 14th May 2007 09:04 PM
Savonius wind generator blade designs, help :P Salaki Electronic Projects Design/Ideas/Reviews 3 1st May 2007 06:00 AM
Model Gas Turbine ECU Barry Micro Controllers 16 22nd May 2006 02:04 PM
Making a wind sensor xcfisher Electronic Projects Design/Ideas/Reviews 13 12th November 2003 05:36 PM
