Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 23rd April 2007, 04:10 PM   (permalink)
Experienced Member
HarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to all
Default Earth Day project
Well, finally got around to starting this thing. I guess the whole Earth Day thing got me going yesterday. I've got 3 sections for a savorius-type rotor glued together, looking around for a lighter shaft. I wanted to recycle some beer cans for the rotor, but after doing some measuring, it seemed a lot taller then I really wanted. Plus I could figure a simple/easy way to cut the cans in half length-wise without crushing or mangling them. Went with some little plastic cup like things. Worked out well, as the diameter was the same as from the edge of a CD and the edge of the hole in the middle. Haven't figured out how I'm going to offset each section 60 degrees when I stack them up on the shaft. Should be able do it by sight.
Going to try a bi-polar stepper for the generator. I've got some 9 volt motors that will light an LED pretty good when finger spun. If the rotor can spin the motor, I'll get light. I went with the savorius rotor for simple construction, and torque rather than speed. Also seemed to be several other advantages. The tough part (finding parts), need to find something to make a 15mm tube fit over a small brass gear on the stepper. Haven't decided to mount the motor on top, bottom, or both and save my self the trouble of finding some bearings or other means to reduce friction on the free end of the shaft.
This is just another yard light thing, might not even go with batteries or much in circuitry. I'd be surprised if it survives the first severe storm.
HarveyH42 is online now   Reply With Quote
Old 23rd April 2007, 07:44 PM   (permalink)
Experienced Member
Hmmm... Could have swore I put this up in Alternative Energy, not the Political Crap forum, maybe the moderator can move this to a more apropriate place.
Really had nothing to do with saving the planet from it's own natural processes, or my lack of political direction. It's about a simple toy project to create some light that doesn't require batteries or extention cord. Pretty well useless in any practical sense.
Kind of sucks, but looks like I might have to go to Home Depot (really hate that place) to find something I can use to attach the motor to the shaft. Going to look around here some more, certain there must be something to spare me the ordeal. Last time I was there they were trying out some kind of self-serve check out.
Old 24th April 2007, 02:23 AM   (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
Have you had a look at the pico turbine. Also, Pico Turbine Manual.
Pommie is online now   Reply With Quote
Old 24th April 2007, 04:24 AM   (permalink)
Experienced Member
Yes, I saw it. Didn't read through to much, made of paper (not so good for outdoors), and you wind your own coils to build the generator. Wanted something that would be setup outside, quick and simple to build, hopefully using parts that will make it repeatable.
I did find a knob that fits over stepper shaft, but need to shave it down just a little to fit in rotor shaft. Should work okay, but not a great solution.
project judgement day near! please help! ramimech Electronic Projects Design/Ideas/Reviews 2 18th April 2007 04:54 PM
FINAL YEAR PROJECT! erique82 Electronic Projects Design/Ideas/Reviews 18 15th April 2007 10:08 AM
What appliance class has a plastic enclosure and an earth connection? Dave#2 Electronic Projects Design/Ideas/Reviews 3 9th May 2006 08:11 AM
A Microcontroller based Analogue Waveforms Analyzer Project km Electronic Projects Design/Ideas/Reviews 76 30th June 2004 06:39 PM
I need a project idea based on my strength or interest. :) janetsmith2000@yahoo.com Electronic Projects Design/Ideas/Reviews 10 11th November 2003 09:33 AM
