Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 4th April 2007, 12:09 PM   (permalink)
Experienced Member
things is on a distinguished road
Default Cd's as wind generator
hi, i have been looking around the internet for homemade wind turbines and have decided to build one my self but was wondering if i could use cd's as the generator using the magnet and coil thing. sorry i have no idea how this works but people say that one plate with coils of wire and another magnets rotating will generate power. i need some advice if this will work and what kind of power i could get. also how would i put this together eg; number of turns on coils, amount of coils,amount of magnets, where to put the magnets.
every bit of info will be appreciated
thanks
things is offline   Reply With Quote
Old 4th April 2007, 05:37 PM   (permalink)
Experienced Member
The term you are looking for is an alternator and going from what you've said you probably don't have enough experience to build one. You can use a stepper motor as an alternator or a DC motor as dynamo then you won't have to worry about building one.
Old 5th April 2007, 09:46 AM   (permalink)
Experienced Member
bryan1 is just really nicebryan1 is just really nicebryan1 is just really nice
Eh Things,
CD's wouldn't be any good for a small axial flux genny as the plates that hold the magnets need to be iron, checkout www.otherpower.com and take a look how to build a real axial flux wind genny. There's plenty of info and links on that site so make sure you do a heap of research as many people have flown in and made them and failed only to find out they didnt do any research.
Cheers Bryan
bryan1 is offline   Reply With Quote
Old 5th April 2007, 12:09 PM   (permalink)
Experienced Member
ericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud of
hi things,
If you want to experiment with a simple turbine, get a second hand bicycle dynamo and mount some blades on it.
If you want more power and a bigger turbine, go to your local car breakers yard and get an old car alternator and regulator,
You are talking big turbine blades!.
Lets know how it goes.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 10th April 2007, 12:54 AM   (permalink)
Experienced Member
the first wind turbine i bought was one of these.www.jointiff.com
but 5 volts 100ma average just isn't very useful for charging batteries or anything. so ive decided to try and make a bigger one.
Old 13th April 2007, 06:47 PM   (permalink)
Experienced Member
philba is just really nicephilba is just really nicephilba is just really nice
I love the image on that page - birds flying through the turbine blades. Yes, I know the blades are small. I just got a chuckle from the imagery.
philba is offline   Reply With Quote
Old 14th April 2007, 12:20 AM   (permalink)
Experienced Member
SPLAT!!! if it was real of coarse.
Old 14th April 2007, 01:06 AM   (permalink)
Experienced Member
Sceadwian is a glorious beacon of lightSceadwian is a glorious beacon of lightSceadwian is a glorious beacon of lightSceadwian is a glorious beacon of light
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
So that's what gnats looks like.
Curiosity killed the cat; That's why they have nine lives.
Sceadwian is online now   Reply With Quote
Old 14th April 2007, 01:22 PM   (permalink)
Experienced Member
HarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to all
How much trouble is it smooth and regulate the output of a permenant magnet motor used as a generator? I've wanted do something small scale like this for a while to run some 5 volt or less simple circuits. I have no idea how to make a simple charge controller for this, maybe 4-6 AA nicad or nimh batteries. When looking at wind generator stuff, it's usually at a much greater scale then what I have in mind, just lighting up some LEDs, like solar yard lights. Some AVR chips work under 2 volts, so kind of getting interested in looking into this again. Using AOL CDs for turbine blades could look cool during the day, with sunlight defracting off the surface.
The thing that really stumps me, is that the output of the generator wouldn't be constant, nor anyway to predict the max frequency (if it matters). We get some pretty strong winds in Florida, so figure any wind generator scheme I build, would eventully get destroyed.
HarveyH42 is online now   Reply With Quote
Old 14th April 2007, 02:39 PM   (permalink)
Super Moderator
Simply connect it via a blocking diode to some NiCd or NiMh batteries, ensure the batteries are of enough capacity to not get overcharged - that's really all you need for a simple design. For a higher power design you would need charging control, so that once the batteries are fully charged the output from the generator is dumped to a dummy load instead of the batteries.
Old 14th April 2007, 03:22 PM   (permalink)
Experienced Member
Pretty sure I would need to detect a full charge, even on such a small scale. We usually get a light breeze, but can really come up fast in the afternoon and evening hours. Unlike the solar lights, these could be charging 24 hours a day. Guess the only way I'm going to learn, is to throw something together, and let it burn...
Old 14th April 2007, 03:34 PM   (permalink)
Super Moderator
Depends on the size of the generator and the size of the batteries, if the average output of the generator is only 1/10th or less of the charging capacity of the batteries there shouldn't be a problem. If it's as high as 1/5th, then double the number of batteries! - and so on.
You can do this with a small generator, and small low cost batteries - you obviously can't afford to do it with a multi-kilowatt job!
Old 14th April 2007, 06:44 PM   (permalink)
Experienced Member
Did some looking on the web for some simplist constructions (science fair type). Think using CDs for the rotor might not be the best option, but got an idea. Found savonius rotor, but on a much larger scale (55 gallon drums). Figure a couple of beer cans cut lengthwise glued to an aluminum arrow shaft would be good enough. The generator would be a small toy motor or stepper (wonder if it makes a difference if its unipolar or bipolar). Probably use the bipolar, since the driver really sux. Wish I would have bought one of those 'never needs sharpening' beer can cutting knives they use to advertise on TV.
Old 12th June 2007, 06:47 AM   (permalink)
Experienced Member
silvarblade is on a distinguished road
is there any wind generator that can be completely made from house hold items??
i would explain it to you but it would make your brain explode!
silvarblade is offline   Reply With Quote
Old 12th June 2007, 08:33 PM   (permalink)
Experienced Member
Depends on what kinds of items are in your household, and what you are willing to destroy or modify. Also kind of depends on your expectations. If you expect to light up a couple of LEDs when the wind blows, a small stepper motor makes a good enough generator. The propeller off one of those cheap rubber band powered planes, and a vane to keep it pointed into the wind.
Of course my house is a cluttered mess, tools in most every room. Most flat surfaces contain a partial built project, or partially destructed source of parts (got what I needed, but still some good stuff there...)
Would like help with voltage boost circuit for Wind Generator. charles25 Electronic Projects Design/Ideas/Reviews 14 8th June 2006 02:10 AM
ammeter for standby generator jwnetsource Electronic Projects Design/Ideas/Reviews 4 3rd June 2006 05:30 AM
analog function generator theory schematic walters General Electronics Chat 13 16th December 2005 04:28 PM
Electric motor as a generator, DC type? Johnson777717 General Electronics Chat 5 23rd June 2004 09:13 PM
Wide Band Signal Generator CParsec General Electronics Chat 1 27th September 2003 02:48 AM
