Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 13th June 2007, 03:09 PM   (permalink)
Experienced Member
silvarblade is on a distinguished road
Originally Posted by HarveyH42
Depends on what kinds of items are in your household, and what you are willing to destroy or modify. Also kind of depends on your expectations. If you expect to light up a couple of LEDs when the wind blows, a small stepper motor makes a good enough generator. The propeller off one of those cheap rubber band powered planes, and a vane to keep it pointed into the wind.
Of course my house is a cluttered mess, tools in most every room. Most flat surfaces contain a partial built project, or partially destructed source of parts (got what I needed, but still some good stuff there...)
i can buy motor and stuff but i only need to produce about 6 to 10 volts just as an experiment to see if we have enough wind here
i would explain it to you but it would make your brain explode!
silvarblade is offline   Reply With Quote
Old 13th June 2007, 06:31 PM   (permalink)
Experienced Member
HarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to all
I'd suggest searching the web, even this forum, and see how other people build theirs. There are a lot of designs and construction ideas on the web, from Science Fair, to comercial power generators. Just see what they look like, and see what you have or can make that is similar. The size is up to you. I'm sort of a beginner too, just started building earlier this year, but had thought about it many times.
For some larger blades, I've got this idea for using a staight-sided shampoo bottle, about 12 inches tall (still about half full...). When it gets empty, I'm going to measure the circumference, divide by 3, maybe 4 blades. Cut off the top, cut down the sides for the blades, and fold them out at slight angle. Might need to heat along the crease to keep them in the right place. I'll mount it direct to a small stepper motor. Hoping the flexiable blades will hold up a little better in stong winds, the my previous ones.
Also have some large 24" acrylic domes I want try on another savonius design, but it's going to take some time to construct, and still need to find some parts. Like a shaft and some bearings to fit, some way to couple the shaft to a motor. Pretty sure I have most everything, just need to do some looking.
HarveyH42 is online now   Reply With Quote
Would like help with voltage boost circuit for Wind Generator. charles25 Electronic Projects Design/Ideas/Reviews 14 8th June 2006 02:10 AM
ammeter for standby generator jwnetsource Electronic Projects Design/Ideas/Reviews 4 3rd June 2006 05:30 AM
analog function generator theory schematic walters General Electronics Chat 13 16th December 2005 04:28 PM
Electric motor as a generator, DC type? Johnson777717 General Electronics Chat 5 23rd June 2004 09:13 PM
Wide Band Signal Generator CParsec General Electronics Chat 1 27th September 2003 02:48 AM
