Experienced Member
If you want to convert solar into power to charge batteries or produce hydrogen then I think Stirling engines would be the way to go. You can get MUCH more efficiency that way. Just focus the solar to produce heat directly on the hot side of the engine. You wouldn't even need to convert it to steam first.
Super Moderator
Experienced Member
yeah, crux of the matter is focusing enough solar energy. Those megawatt solar plants use hundreds or even thousands of steerable mirrors to concentrate the solar energy. Though, they generate steam to turn turbines.
I think the calculations of how much power you could get from a Stirling engine is fairly easy. at least you should be able to compute heat gain for the footprint of a concentrator. Inefficiencies for a specific device will be harder to determine, a priori. |
Experienced Member
Using solar power to directly power vehicles is a non starter in northern latitudes.
Solar power is best generated in at static sites and transported to where its needed At present CSP (Concentrated Solar Power) appears most promising. There was a study (6Mb pdf) done in Germany about building CSP stations in the Sahara and transporting the power to Europe. |
Here's a link about a solar farm being built in Ontario. It doesn't give much as far as specifics, but it would seem that they wouldn't build it if it didn't make sense financially. I agree that wind is probably a better option for those that have enough of it.
I think that for alternative energy to work that several methods will have to be used to take advantage of whatever resource a particular area has, be it wind, solar, geothermal, the ocean or whatever. I say use whatever you can that makes sense. http://news.yahoo.com/s/nm/20070426/...M6EvX1S84PLBIF |
Moderator
Money down the drain. Should have invested in research.
From link. Quote:
The solar farm will stretch across nearly 365 hectares. Money down the drain. Should have invested in research.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
Experienced Member
One of the coolest solar ideas- the updraft tower:
http://en.wikipedia.org/wiki/Solar_updraft_tower Large areas of just cheap black surface heat the air underneath so it rises through the tower. However, a TALL tower is required. The idea will not work with a small one at home. Towers of up to 1000meters have been suggested. You gotta admit, saving the earth aside, a spire over half a mile high would be an inspirational piece of art. Screw biodiesel algae farms, this one kicks ass for style.
I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 27th August 2007 11:05 PM |
| EFI Fuel Circuit | akajee | General Electronics Chat | 2 | 17th January 2007 06:45 AM |
| FET & Fuel Gauge - perplexed! | rackley | Electronic Projects Design/Ideas/Reviews | 12 | 22nd December 2006 06:25 PM |
| Charging NiMH batteries | bonxer | General Electronics Chat | 2 | 9th June 2005 11:48 PM |
| Energizer® e˛® Lithium Batteries for Digital Camera... | erabell | General Electronics Chat | 7 | 15th January 2005 12:55 AM |
