Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 18th March 2007, 09:58 AM   (permalink)
Experienced Member
Thunderchild is just really niceThunderchild is just really niceThunderchild is just really nice
Send a message via MSN to Thunderchild Send a message via Yahoo to Thunderchild
Default a couple of old solar pannels
So I have these two little solar panels out of some quite old solar lights. they are each made of 8 little panel elements (see panel image below) I decided to remove them from the silly plastic casing that was most certainly reducing the light especially after turning yellow in fact the increase after removing the plastic has been by 50 % or more, (from 60 mA to 100).
so my problem is one element looks cracked (see detail picture below) I think possibly in removing it from the plastic. I am not sure if this will reduce the performance, the two panels that are identical are giving out the same power so there seems to have not been any loss. 4.5 Volts up to 120 mA.
any ideas on what I can do with these panels ? just for fun and perhaps useful ?can I charge NiMH batteries with them ?
They seem coated with glue/silicone is it worth trying to remove it ? perhap consider removing it AND putting them under glass ?
my site:www.simons-photography.com
http://rushdenrotaract.org.uk
see also
http://www.bigstockphoto.com/account...fid=m2URATYch5
http://www.redbubble.com/people/simonsphotography
Thunderchild is offline   Reply With Quote
Old 18th March 2007, 10:21 AM   (permalink)
Experienced Member
It's possible that the cracked panel is still working; the connections to either side of the semiconductor cell appear to be both intact so I'd leave it well alone if I weere you.
Old 18th March 2007, 11:08 AM   (permalink)
Experienced Member
House0Fwax is on a distinguished road
I agree with Hero999 on this one. Though for your own peace of mind, you could try covering the other panels with thick card ( or similar ) and see if you get a reading from the cracked panel.
House0Fwax is offline   Reply With Quote
Old 18th March 2007, 11:21 AM   (permalink)
Experienced Member
yea well as they are encased in glue/silicone I can't read each element perhaps if I run into a particular requirement voltage and amperage wise I might dismantle them and discard the cracked one and rearrange them but thats not an immediate issue as I'm still thinking on what to do with them. How much soldering can these things take ?
there will be 16 total (including the cracked one) elements so that leave quite a few combinations for different power ratings
see also
Old 18th March 2007, 11:23 AM   (permalink)
Experienced Member
what voltage should I consider per element in calculations for a project ? if I am charging batteries with a number of elements in parallel should I put a diode on each or can I connect then all in parallel and then to the diode ?
see also
Solar Power LED Array (Dead Simple) simoin Alternative Energy 21 25th November 2007 11:13 AM
Solar battery charger with moving panel Hanford Electronic Projects Design/Ideas/Reviews 6 8th October 2006 01:38 PM
Solar pannels - where can i get them ? Thunderchild General Electronics Chat 6 28th August 2005 03:56 AM
DC/DC Converter (Miniature Remote Control Solar Car) devonsc General Electronics Chat 167 21st December 2004 04:36 AM
Solar Car Archangel4life Electronic Projects Design/Ideas/Reviews 4 31st March 2004 07:31 AM
