(permalink) | ||
Super Moderator
Experienced Member
well when measuring the CRT with an ex electric boards meter it was 90 or more watts I think
I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk see also http://www.bigstockphoto.com/account...fid=m2URATYch5 http://www.redbubble.com/people/simonsphotography |
Experienced Member
Did you just use a current meter again?
If so you might be incorrect, sure it's using 90VA but it doesn't mean it's using 90W. |
Experienced Member
no for the CRT i used an ex electric board meter so it measured what the electric company will read and charge for
Experienced Member
Going back to the original post on knowing how much energy your using this is a very nice device about to be launched in the UK
http://www.currentcost.com/ I want one! |
Experienced Member
In fact I was in the process of doing my own when I can across it.
As a general offer I'm offering my time free for a project that needs coding help if it will have an impact on saving energy and global warming etc |
Super Moderator
Check the last two issues of EPE, they have a suitable project!.
Experienced Member
Well, back to the original question:
Voltage and phase MUST be measured along with current to produce an accurate reading. Otherwise you will be including reactive power along with the real power and you only have an interest in real power. The power company's glass bubble meter uses a mechanical, yet surprisingly accurate mechanism that inherently takes into account voltage, current, and phase angle. Pretty neat, actually. In fact a digital device has to be well-designed and a bit complicated to approach the effectiveness of the bubble. You can manually read the dials to find you consumption day-by-day, and read you power company's KWH cost to figure out what you use over a fixed time period. There's a device called a "KILL-A-WATT" meter that Harbor Freight Tools sells now. These are quite nifty. They'll measure the consumption of anything you can plug into a 110V outlet. It'll show real power consumption, power factor, total KWH consumed since it was reset, just about anything you could want. This may even be more helpful than a "whole house" meter because that would not clearly spell out what each device costs. Well, the KILL-A-WATT can't measure your room lights that don't plug in, but then a 100W bulb pretty much takes 100W, doesn't it? I've measured my PC and monitor. IIRC that thing was well over 200W, pretty hefty cost being left on all the time.
I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
Experienced Member
and what monitor do you have ?
Just to spell it out to the disbeleiving people that practically called me a liar: My dads 17" CRT said in the instructions 105 W My new 19" flat screen in the instructions says 42 W so there you have it straight from the mouth of the manufacturer now am I a liar ? considering that my monitor has photo and video inhancement ability's that I don't use it is likely that I use less than 42 W or at least I hope so if this thing was green mindedly designed
Experienced Member
Shoot was in Harbor Freight today, forgot to look. I will check the web as well. I toy I must have.
Thanks Oznog.. |
Super Moderator
Experienced Member
CRTs use less with a black background and more with a white background. That is why some people were trying to get Google to turn their background to black, save energy.
As far as LCDs being much more efficient than CRTs, of course they are. I can't believe some of you are even arguing that. Some of you are stating how much power it consumes by what the power supply is rated at? Come on, that is complete BS! The power that power supply uses depends on it's load. I really thought better of some of you... As far as turning off computers, it is a good idea. But if you need the super quick boot time, put it to sleep. I have an intel iMac and it uses 3 watts (via Kill-A-Watt) when it is sleeping. This is the same amount of power it uses when it is off, since it is not completely unplugged when it is off (digital on switch). So I just have my computer set to goto sleep after 10 minutes of no use, and if I am going to be gone for the weekend I unplug all of my stuff so it draws no extra current. |
Super Moderator
Experienced Member
I have measured, as I have both LCDs and CRTs. What you are saying is not accurate.
If you insist that it is, show me a source that shows that CRTs use even close to the same amount of power as an LCD of the same size. |
Super Moderator
| Evanescent Coupling?!? A new way to transfer electrical energy? | Analog | General Electronics Chat | 20 | 11th June 2007 02:46 AM |
| Pickit 2 - Build or Not 2 Build | art-666 | Micro Controllers | 2 | 5th February 2007 11:40 PM |
| I Thought This Forum Was About Alternate Energy | bryan1 | Alternative Energy | 12 | 13th August 2006 11:43 PM |
| Links to Alternate Energy Websites | bryan1 | Alternative Energy | 0 | 4th July 2006 10:39 AM |
| damping | niga | General Electronics Chat | 11 | 7th June 2005 07:04 AM |
