Experienced Member
I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk see also http://www.bigstockphoto.com/account...fid=m2URATYch5 http://www.redbubble.com/people/simonsphotography |
Experienced Member
Did you measure you dad's CRT as well?
9.6W, even though due to losses in the PSU it's more likely to be 11.52W it still seems too good to be true. |
Super Moderator
My 19 inch LCD has a 12V 4.16A power supply, that seems about right for an LCD - a smaller one will take slightly less of course.
Comparing TV and LCD, LCD's usually take more power than similar size CRT sets, and Plasma take more again. |
Experienced Member
Super Moderator
Did you use a true RMS meter to measure the current?, if not it bears no resemblance to the actual current - I had occasion to scope the input current of a switch-mode PSU the other day - I was surprised at the actual waveform I got, and it would completely ruin a normal meter reading (nothing near a sinewave).
Experienced Member
You're better off looking at the current rating on the power supply, better still use a true RMS meter and measure the AC side.
Experienced Member
I measured between the 12 DC output and the power conector of the monitor, yes I cut the wire to put in my tester set to amps I measured it as DC, as for the wattage of the CRT I used a refurbished electric board meter the same one used to measure and bill you for you mains power consumption i got it at the electric shop as they are switching to digital meters now and puting the old mechanical ones on the market reset to 0.
Experienced Member
my LCD power supply does say 100-240 V 1.0 A of course as I said before it draws nothing of the kind
Experienced Member
Just because you're measuring DC it doesn't mean that you can ignore the RMS meaurement, if a load isn't drawing a constant current then the reading using a DC meter multiplied by the voltage won't necesarely give you the power consumption. The only way you can gaurantee you're reading an accurate power reading is to use a power meter on the mains side because it will take into account of the power factor which a meter won't.
Experienced Member
well if you consider most of the power is used by the back light I think thats a pretty constant load isn't it ? as the monitors crystalls are refreshed 60 times a second that's a pretty constant figure it's not an electric car is it I think your being a bit too picky here the fact IS that LCD use a lot less than CRT, also the same power adapter has been used for other things as well, I have also used it to run a fan drawing around 3 amps and it go quite warm at the moment it is cold wile powering the monitor, any other silly exscuses to disbelieve my readings ? how would I measure RMS ? I only have a DC amp meter can I use it for ac with a rectifier in any way ? I could send 220 VDC to the power supply as the AC is getting immediately rectified any way.
Also remember my monitor is an old LCD (3-4 years) so possible comsumptions have even improved
Super Moderator
Experienced Member
The easy way to measure power consumption is heat. If it's warm it's using power. CRTs are warm LCDs aren't. I can't believe anyone is arguing different. If CRT's were power efficient they would use them on mobile phones.
As for not measuring true RMS. Are there no capacitors in them there power supplies? DC in is normally smooth and so is very close to true RMS. Mike. |
(permalink) | ||
Super Moderator
Experienced Member
oh thank you oh gods what suddenly made you change your minds ? I do have to say I erred in comparing the 19" (got mixed up with what the original poster said) I was refering to 17",
My dads 17" CRT as stated by the manual uses 105 W my 15" monitor that is only 0.5 cm (0.2") smaller than the 17" CRT uses 20 watts AT MOST ! now I hate to immagine what that guys kids 19" CRTs are using more like 120 watts each at least so we are looking at 360 W for the monitors before counting 80-120 W for the computers he could easily be using 700 W for his kids computers and then wonders where it goes....
| Evanescent Coupling?!? A new way to transfer electrical energy? | Analog | General Electronics Chat | 20 | 11th June 2007 02:46 AM |
| Pickit 2 - Build or Not 2 Build | art-666 | Micro Controllers | 2 | 5th February 2007 11:40 PM |
| I Thought This Forum Was About Alternate Energy | bryan1 | Alternative Energy | 12 | 13th August 2006 11:43 PM |
| Links to Alternate Energy Websites | bryan1 | Alternative Energy | 0 | 4th July 2006 10:39 AM |
| damping | niga | General Electronics Chat | 11 | 7th June 2005 07:04 AM |
