Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 31st December 2006, 03:59 PM   (permalink)
Super Moderator
Originally Posted by philba
On the first point, they would have had to change the compression ratio since diesel works by compressing the fuel/air mixture to the point where the heat is above the ignition point. NG/air mix combusts at a much lower temp and thus would cause problems for the engine. The more I've investigated, I think diesel to NG conversion is impractical.
Seemed a bit of overkill to me?, basically converting the diesel engine to be a petrol engine, then run it on gas - SERIOUSLY big modifications. Considering a diesel engine costs a LOT more than a petrol one, why not start with a petrol engine in the first place?.
On the second paragraph. Yeah, sure, whatever. plus there was second gunman on the grassy knoll, there really are aliens being held in area 51 and the tooth fairy is real.
What do you mean?, the tooth fairly isn't real!
Old 31st December 2006, 10:50 PM   (permalink)
Experienced Member
philba is just really nicephilba is just really nicephilba is just really nice
Yup and let me tell you about santa claus...
philba is offline   Reply With Quote
Old 1st January 2007, 06:54 PM   (permalink)
Experienced Member
hmmm, convert this one to gas???
http://www.ultimatestupidity.com/pics/1/diesel/
Old 1st January 2007, 07:03 PM   (permalink)
Super Moderator
As you go around the UK you come across various old engines, in museums and even still in use - it's amazing what they run off, some use petrol, some diesel, some gas, some paraffin, some just off oil (like very thick diesel).
Here's a steam engine you can see running at Sheffield http://www.simt.co.uk/collections/collections-2-1.html, it's seriously impressive - it was from a rolling mill, so moved large metal plates back and forth between rollers. As such it has to reverse direction VERY quickly, you wouldn't believe something that big could do it!.
Old 16th March 2007, 09:21 PM   (permalink)
leetate is on a distinguished road
Default diesel to ng conversion
Yes, it is quite possible to convert a diesel engine to run on natural gas, or even propane. I worked for Caterpillar for many years and they converted their diesel engines to work on natural gas. The secret is that diesel engines use a compression ratio of 22 or so to one. That is the secret of the cycle as the compression heat ignites the fuel mixture. Gasoline engines usually work at lower compression ratio to prevent pre-ignition, or "pinging". The diesel ignition works on a cetane value, whereas the gasoline engine works on an octane value. Caterpillar converted diesel engines to natural gas by merely adding thickness to the cylinder gasket to lower the compression ratio, and then replaced the injectors with spark plugs and a magneto. I installed many of these units for various purposes, as the more robust engine parts of the diesel engines would mean much more reliability. Incidently, the octane rating of propane is much higher than gasoline.
leetate is offline   Reply With Quote
Old 16th March 2007, 10:26 PM   (permalink)
Experienced Member
But did the power level drop? If so by how much?
Old 17th March 2007, 02:44 PM   (permalink)
The point in converting a diesel engine was not about power, but reliabity and convenience. The engines converted ran on natural gas. Most run of the mill gasoline engines have a compression ratio of around 7 or 8 to one. A diesel is more efficient since it runs at around 22 to one. Propane engines can run around 12 to one without pre-combusting. The harder the squeeze on the fuel mixture, the bigger the bang. The octane rating is a number relating to how much you can compress a mixture without causing it to self ignite. The cetane rating is how hard you have to compress a mixture in order to get it to self ignite. A diesel engine has the advantage of not making a mixture until the air is already compressed past the point of self ignition. When you use high octane fuel in a low compression engine you are throwing money away.
Old 17th March 2007, 06:02 PM   (permalink)
Experienced Member
Sceadwian is just really niceSceadwian is just really niceSceadwian is just really nice
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
Diesals will burn pretty much anything if it's the right mixture of fuel to air. What about emissions though? In that case efficiency is important due to the massive amounts of pollution that can be thrown off, no matter how cheap or readily available the fuel is.
Curiosity killed the cat; That's why they have nine lives.
Old 17th March 2007, 08:27 PM   (permalink)
The purpose of this thread is to make a diesel engine converted to run on natural gas. In that event the polution would be insignificant because it would be a clean fuel to begin with.
Old 17th March 2007, 08:35 PM   (permalink)
Experienced Member
Inefficiently burned natural gas produces as much or more polutants than regular diesal or generic combustion engines do when running efficiently, you seem to think there is such a thing as clean fuel =) It's all burned in one way or another it's all dirty.
Old 20th March 2007, 01:07 AM   (permalink)
I do not deny that any hydrocarbon engine produces zero carbon dioxide/monoxide emissions. However for emergency electrical usage the engine, whether converted from diesel, or conventional home depot engine, is insignificant compared to the countless streams of automobiles seen on the nations freeways for nothing more than transporting a human being from point a to point b.
Old 20th March 2007, 01:32 AM   (permalink)
daybrown is on a distinguished road
Diesel has lubricant properties that LPG & gas do not. You cant expect the same durability.
daybrown is offline   Reply With Quote
Old 22nd March 2007, 08:35 AM   (permalink)
Aloefundi is on a distinguished road
Hi Philba
When reading your post something was niggling in the back of my mind wrt Ng in a diesel. I did a search and this is what came up.
http://www.motherearthnews.com/DIY/1...-John-Fry.aspx
John Fry lived in ZA for a number of years and he apparently ran a diesel on methane. I havn't looked for any design layouts however reading the article again it looks like a bit of 'imagineering' would be required.
regards
Aloefundi
Political Correctness is a doctrine fostered by a delusional, illogical liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end - "Unknown"
Aloefundi is offline   Reply With Quote
Old 22nd March 2007, 05:19 PM   (permalink)
Experienced Member
thanks, interesting article but it just reinforces my belief that there isn't clean solution to be had from a deisel engine. By clean, I mean easy to obtain and run.
Since this is for only occasional usage, I am less concerned about pollution and far more about reliability and low(er) maintenance requirements. The focus on NG is to avoid having to treat and/or manage a liquid fuel. It looks like a gasoline engine conversion is the best bet. I'd still have to deal with oil changes but that's probably acceptable. Especially if the controller can remind me when it's needed.
Interestingly enough, a very large part of the installation cost will be the transfer panel and associated wiring. This is due to the complexity of my site wiring.
USB to RS232 conversion chintan_jagani Electronic Projects Design/Ideas/Reviews 8 12th October 2006 03:21 AM
PIC 16F877A - Problem with A/D conversion disco_dave Micro Controllers 11 17th February 2006 02:54 AM
Serial to Gameport Conversion Draqo Electronic Projects Design/Ideas/Reviews 8 9th March 2005 08:44 AM
How to actually use the value generated by A2D conversion? Lac Micro Controllers 1 19th January 2005 05:55 AM
S video conversion sinetific Electronic Projects Design/Ideas/Reviews 1 14th November 2002 12:16 PM
