Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 11th September 2006, 11:20 AM   #1 (permalink)
Experienced Member
bryan1 is just really nicebryan1 is just really nicebryan1 is just really nice
Default My Latest Projects
Hiya Guy's
Well I've been busy I'm finally on making up my fisher& paykel wind genny but it's not so urgent now as I have to wait until I can get the new shunt regulator Oatley's are bringing out and my new 3kw sinewave inverter won't be here until the end of the month. I recently got 30 - 6 volt 105 amp/hour agm batteries for $250 so these batteries will be the base behind the new power scheme for my shed. As I already have 8-65 watt solar panels hooked upto 2 - 12 volt 200 amp/hour wet cell batteries and a 1700 watt mod sinewave inverter which isn't much chop. Anyway I'll take 6 of those 65 watt panels for the new array and keep the other 2 for the wet cells and change the panels back to 12 volts. This way I can dedicate the new battery array to the more seroius stuff like running my lathes and mills and the wet cells can have a mundane life providing lights and a 12 volt power source.
Another project is using a 5hp briggs & stratton motor hooked up to an F&P and I'm going to see how much amps I can get before the magnet stator melts but it doesn't matter as I can get F&P motors cheap but the idea is at what rpm 1400 or 1600 will give over a kilowatt of power at 24 volts. My mate who is a pioneer with the F&P is willing to help in this project so it could prove fruitfull.
So here's a topic revelant to alternate energy and I love love some comments to come in as I'm totally reliant on R.E. and I would like this part of the forum to be more Alternate Energy rather than scams like sterion etc.
Cheers Bryan
bryan1 is online now   Reply With Quote
Old 11th September 2006, 08:43 PM   #2 (permalink)
Experienced Member
Hero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to beholdHero999 is a splendid one to behold
What about safety, are you going to have fuses on the batteries and earth one side of the output from the inverter for the neutral connection?
Hero999 is online now   Reply With Quote
Old 12th September 2006, 03:09 AM   #3 (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
Brian,
Could I inquire where you get your F&P motors from. I see from another thread you only pay $20 for them. At that price (or even double) I am very interested.
Pommie is online now   Reply With Quote
Old 12th September 2006, 09:34 AM   #4 (permalink)
Experienced Member
Hiya Mike,
If you look at the freecycle website in your local area I'm sure F&P washing machines will comeup all the time like they do in Adelaide. Anyway my good mate has a deal with a local scrap mob and gets them for nothing and when I need one I pay him $20 to strip the washing machine down. Also mate checkout the backshed link I've put in the sticky as that site has everything you need to know about F&P gennies also with a great Aussie forum.
Hero Wrote;
Of course i'll have fuses setup, all my solar array's already have fuse's in place. Now where on earth did you comeup with the neutral connection on an inverter is 24 volts DC input and 240 volts AC output .
The shunt regulator will cut the load to the batteries when a preset voltage is reached and will be diverted to a dumpload which will be around 80 metres of heating wire setup as 4x20 metre strands in parrallel. This will all depend on what Oatley's bringout with their new improved shunt regulator kit.
Anyway when I get my new digital camera I'll put some photo's up to show my setup.
Cheers Bryan
Old 15th September 2006, 09:45 AM   #5 (permalink)
Experienced Member
Hiya Guy's,
Well yesterday for a sum of $400 Oz money I managed to pick up 24 2 volt 275 amp/hour batteries which came off a ups system that never went into backup mode. I intend to set these up as 24 volt array's and put them in parrallel with my house batteries which are 12- 2 volt 600 amp/hours. Silly me forgot to get some S.S. bolts today so I'll have to wait until monday to get them setup. On measuring each battery they each measured between 2.22 to 2.25 volt which means they are still fully charged. Now I did the sums today and off memory I should have around 13,600 amp/hours for my house array. Not bad, I reckon it's time to install a 2hp split aircon for summer and when the mass's in town are suffering from power drop outs we'll be laughing and staying cool. Now when I finally get around to hooking up a wind genny on the house array I reckon I can get a mains system hot water tank put 24 volt heating elements into it and heat my water from the excess power from the wind genny and still keep the batteries in a good state due to the 14 kaneka thin film panels on the roof and the wind genny spinning away.
Anyway when I finally get my new digi camera I'll take some picks and throw into my anotherpower album http://www.anotherpower.com/gallery/bryan
I haven't upadat the album for a while but the album does show some of my gear on the farm
Cheers Bryan
Old 15th September 2006, 02:33 PM   #6 (permalink)
Experienced Member
Some inverters internally have the neutral connected to DC 0V, this is how it should be since if the AC is connected to the DC bus a fuse will blow while some inverters have the output totally isolated from the input. Either way in a domestic environment the neutral connection should be earth-bonded using a a large metal stake in the ground, it's probably easiest to just connect it to the cold water pipe which will be earthed anyway.
Old 19th September 2006, 06:06 AM   #7 (permalink)
casdon56 is on a distinguished road
thanks for your info....they are realy nice!
casdon56 is offline   Reply With Quote
Old 19th September 2006, 04:21 PM   #8 (permalink)
Experienced Member
williB is on a distinguished road
hey Bryan,
You could send the excess power from the solar to water heaters and skip the dump load alltogether , good stuff !
williB is offline   Reply With Quote
Old 20th September 2006, 08:29 AM   #9 (permalink)
Experienced Member
With regard to windmill design or rather windmill electronic controller design. Does anyone know of any sites that discuss the relationship between windspeed, power and efficiency.
For example,
In a 20mph wind, as I take more current the voltage will drop and the blades will slow down. At some point I will get maximum power out of the 20mph wind. If my blades go 60rpm with no load, I may get maximum power at 54rpm(10% slip) or 30rpm (50% slip). Is there an equation or rule of thumb to calculate the ideal "slip".
Old 20th September 2006, 04:33 PM   #10 (permalink)
Thats Good, I Like Your Work
Old 20th September 2006, 06:21 PM   #11 (permalink)
Experienced Member
For example,
i think the only way to determine , the relationship between windspeed, power and efficiency is by actual testing of the blades and alt together..
This is the main reason i am making my data logger , to be able to say my blade design will produce Y power at X windspeed....
the blade calculator below will show the relationship between blade output power and windspeed and efficiency of the blades (not the alternator)
http://www.alton-moore.net/wind_calculations.html
i also use warlock blade calculator ,but the site is not up at the moment for download...
Old 21st September 2006, 04:16 AM   #12 (permalink)
Experienced Member
Warlock is back up .
i like this calculator because it gives the chord length in inches
http://www.warlock.com.au/bladecalc-abstract.htm
Old 24th September 2006, 08:01 AM   #13 (permalink)
Experienced Member
Hiya Guy's,
Well it looks like I'm getting hold of 4 new solar panels, each panel is rated at 175 watts with 36 volts dc output. My mate who already has one has managed to split the panels to get 3 strings at 12 volts. So I have a spare plasmatronics 24 volt solar controller and I'm going to setup the new 275 amp/hour batteries in 2 strings of 24 volts and put them in parrallel to my current battery array. Now with the increased solar array I'm putting in I will have about 1.6Kw of solar power and around 1600 amp/hours worth of agm battery power. Now with the extra Re capacity I will be able to turn my fridge over from using gas to electricty, be able to heat water and in all I should be able to cut our monthly bill by about a 1/2 of the current spending and with the cost of the upgrade I will amortize it within 2 years.
Cheers Bryan
Old 24th September 2006, 01:08 PM   #14 (permalink)
Experienced Member
mramos1 is a jewel in the roughmramos1 is a jewel in the rough
Where did you get the panels? They sound nice for sure. Were they expensive?
mramos1 is offline   Reply With Quote
Old 26th September 2006, 11:39 AM   #15 (permalink)
Experienced Member
Hiya Mramos,
Well a mate of mine found a bloke selling them and got onto me straight away, they cost $500 each and on research the price of a new one is about $1,700-$1,800 each. I was supposed to get them today but the bloke selling them went fishing for the day so I'll pick them up tomorrow arvo. Also my 3kw sinewave inverter will be finally turning up this week so as far as RE goes I'm in for a big week. Once I get everything hopefully I can borrow my works digi camera so i can get a few photo's.
Cheers Bryan
