Experienced Member
Well Guy's a salesman at work today threw a heap of electronic gear in the scrap metal bin today and I just had to take it home to see what goodies were in them
Cheers Bryan
" The only way to avoid human error is to avoid the use of humans" |
Experienced Member
Hey ya Brian, i'm in Adelaide, have just got hold of a Fisher and Paykel washing machine, not sure what model yet, but will be looking at it this week to make into a wind generator. Did you buy stuff for yours from http://www.www.ecoinnovation.co.nz/ ??? I have found some reasonable instructions for how to build one up, for free online at, http://www.thebackshed.com/Windmill/fp2a.asp
Will let you know what sort it is and I how I get along with it, if it turns out to be the correct sor of Fisher and Paykel, will start a new thread about it. simoin |
Experienced Member
Hiya Simoin,
I got my f&p motors locally at about $20 each off memory and I've wired one of them per Glenn's instructions in his siliconchip 3 part article from awhile ago. If your lucky that f&p motor might be one of the new ones but in any case just follow the guide on the backshed site and you'll have no problems. You might want to join the backshed forum too mate as we are all f&p wind genny nuts in there and theres plenty of guy's will answer any questions that might arise. Cheers Bryan
Experienced Member
Hiya guys,
Well I finally got this 10kw 4 pole motor stripped and ready to start figuring out stuff for the conversion. I've made an album in my anotherpower album http://www.anotherpower.com/gallery/...tor-conversion When I get some spare cash i'll get the magnets (about 100 1/2"x 3/8" round). and machine down the stator to suit the poles in the motor. As this is my first conversion I've got a heap of research to do as with a project of this size mistakes aint an option. This is going to be a long term project as the tower needed to hold this baby will be a huge one and I reckon 18' blades would suit. Anyway enough for now hopefully I can get going on it but I still need to finish off converting the bridgeport to a VDF drive so I can use the mill off my inverter. Cheers Bryan
Experienced Member
Well guys with winter setin my current kaneka thin film panels just aint cutting the mustard and charging the batteries so the motor conversion has gone on hold and i'm on making a solar tracker for my 175 watt solar panels which have been sitting in the shed idle. I've made the frame which measures 3.320 x 1.200 metres and when the panels are fitted the total weight will be over 100kg's. so i've made the frame out of 40x40x3 RHS and the tower is 100x100x6 RHS. Once I get the unit up and running I'll take some pic's and put them in here. Once I'm convinced the 700 watts will safely charge my battery bank I'll take the 14 kaneka's offline and make 2 trackers 1 being 8 panels and the other 6. At work we sell linear acuators so next week I'm going to get one and between me and a mate we've workedout using 2 led's and a simple pic circuit we can track the sun so the unit will be totally automanous and hopefully provide plenty of current to charge my house array.
Thats all for now Cheers Bryan
Experienced Member
I'm not surprised your pannels aren't enough to recharge the batteries in the winter time.
How about just adding more pannels? It might work out more cost effective than building a solar tracker. |
Super Moderator
Experienced Member
Time will tell Cheers Bryan
Super Moderator
Obviously if you're only using a single actuator, then you need a polar mount (like satellite dishes use), so that it tracks in a curve and not in a straight line. We'll be interested to see your results from it!. Perhaps you've heard of C.A.T. in Wales, I went there a few years back, you might find this interesting? http://www.cat.org.uk/information/ca...154933&start=1 Last edited by Nigel Goodwin; 18th June 2007 at 10:49 AM. |
Experienced Member
Hiya Guy's
Well I finally got my first F&P wind genny up flying last weekend and good ol' murphy was around ensuring I didnt get any wind. Cheers Bryan
Experienced Member
i've wired the stator up for my F&P genny, what size blades are you using? I am buying some stuff to setup the mount for it this or next week. If you end up with spare blades let me know
How do you mean 12foot between the tower and the blades? |
Experienced Member
Hi simoin,
Eh mate 12" = 12 inch's not 12' (foot). Anyway for blades I suggest you take a look at the link in the sticky and go to the scoriag site and download the plans for making blades. A few blokes make blades from pvc pipe and are quite successfull but the amount of work shaving the pvc to get the pipe correct to the blade contour your better off just making them from wood. However if you just want to buy a set of blades Trev in the backshed forum who is based in Qld sell fiberglass blades for a good price, you might want to check them out. Cheers Bryan
Experienced Member
Bryan
If you need any help with your sun tracker just say, I'm fairly good at sizing drives - and control systems. |
Experienced Member
Well Guy's,
I did say I'll put a pic of my wind genny in here but not what you would expect. Rather than takeup server space here is a link to to a thread I did on the backshed site. http://www.thebackshed.com/Windmill/...p?TID=743&PN=1 Cheers Bryan
Experienced Member
I had a TV antenna mast bend like that.
Uncle $crooge |
