Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 12th August 2006, 12:56 AM   (permalink)
Experienced Member
Overclocked is on a distinguished road
Send a message via AIM to Overclocked Send a message via MSN to Overclocked Send a message via Yahoo to Overclocked
Default Making Hydrogen
Im a bit confused here. I know that Electrolysis will split water, but what comes out? I always assumed Hydrogen and Oxygen came out, but this website says else wise.
http://www.energyquest.ca.gov/projects/split_h2o.html
As the electricity from the battery passes through and between the electrodes (the pencils), the water splits into hydrogen and chlorine gas, which collect as very tiny bubbles around each pencil tip.
Chlorine Gas? I thought Chlorine and Oxygen where Both generated? All Other sites dont comfirm what this site is saying, So are they wrong? Or am I wrong?
If so, What else can I use Besides Salt water? I also want to generate O2 along with Hydrogen. According to this site http://jchemed.chem.wisc.edu/jcesoft...N/CD1R1520.HTM
I can use Sodium Hydroxide, which is in bleach and Dranio
Overclocked is offline   Reply With Quote
Old 12th August 2006, 01:04 AM   (permalink)
Experienced Member
_nox_ is on a distinguished road
Send a message via ICQ to _nox_ Send a message via MSN to _nox_ Send a message via Skype™ to _nox_
2H2O + 2NaCl -> Cl2 + H2 + 2 NaOH ... i guess
iČ = jČ = kČ = ijk = -1
_nox_ is offline   Reply With Quote
Old 12th August 2006, 10:08 AM   (permalink)
JoeElectron is on a distinguished road
Their explination does not make much sense but the result is correct.
Na+ + Cl- + H2O → Na+ + 1/2Cl2 + 1/2H2 + OH- (From http://www.webelements.com/webelemen...xt/Cl/key.html)
All I can suggest is trying other ionic compounds such as vinegar (acetic acid, CH3COOH), sulfric acid (H2SO4), ammonia (NH3), or any other substance that will dissolve in water. All you need is something to ionize to carry the current between the cathode and anode.
JoeElectron is offline   Reply With Quote
Old 12th August 2006, 02:35 PM   (permalink)
Experienced Member
theinfamousbob has a spectacular aura about
I'm pretty sure that only completly pure water won't do what you want...
Ordinary tap water will do fine.
http://powerlabs.org/waterarc.htm
-Ian
theinfamousbob is offline   Reply With Quote
Old 13th August 2006, 02:52 PM   (permalink)
Experienced Member
jbeng is on a distinguished road
A nearby water purification plant uses electrolysis to produce sodium hypochlorite solution from salt water. They add the NaOCl to the water supply in small amounts to inhibit bacterial growth instead of using chlorine gas. Producing it themselves on-site is far less dangerous (on probably much more economical) than having to store and maintain liquid chlorine cylinders and such. Seems to me that if ammonia (NH3) would work sufficiently, it would be best. That is, for every water molecule you would get 2H+O and every ammonia molecule 3H+N. Of course, this would only be true if both molecules would actually electrolyze.
The added salt (to make the water more conductive) was likely where they were getting the chlorine in the original equation. Some of the other equations posted seem reasonable, too.
JB
jbeng is offline   Reply With Quote
Old 13th August 2006, 03:57 PM   (permalink)
Experienced Member
Marks256 is a glorious beacon of lightMarks256 is a glorious beacon of lightMarks256 is a glorious beacon of lightMarks256 is a glorious beacon of lightMarks256 is a glorious beacon of light
If you want to make large amounts of hydrogen, then i would suggest taking some stainless steel wire/bolts, and then stick them in a jar(glass jar). Then fill the jar half full of Hydrogen Peroxide, or H3O, and the other half with regular tap water. Fill a plastic pop bottle full of water, and the put it upside down in the jar, just above the Anode and the Cathode(Make sure no air is in the bottles). I am not sure what side the hydrogen comes out of, i think it is the cathode. So, - = Hydrogen, and + = Oxygen. I have attached a diagram.
Marks256 is offline   Reply With Quote
Old 13th August 2006, 08:39 PM   (permalink)
Experienced Member
Oznog is just really niceOznog is just really niceOznog is just really nice
Send a message via AIM to Oznog
Hydrogen peroxide is H2O2, NOT H30! It is no different than water except that oxygen breaks down out of it fairly easily then it's std electrolysis.
Stainless is not a great electrode. It will dissolve into sludge and release chromium ions which are an environmental problem long after they're flushed down the drain. They're also a pretty high resistance and make a lot of heat. If you want to do a small experiment, it's not a real problem though, just add a bit of salt.
Any real electrolyzer uses an extremely caustic alkaline solution and platinum-plated electrodes. Most do it at as high a temp as is practical because electrolysis is more electrically efficient there, it actually absorbs the thermal energy (requiring less electrical energy) to make hydrogen, constantly cooling the solution in the process. Thus you need a high temp heat source to keep the solution heated.
Oznog is offline   Reply With Quote
Old 14th August 2006, 02:20 AM   (permalink)
Experienced Member
Yes, i am sorry, H3O is heavy water. Yes, H2O2 Is correct, so you will get equal amounts of each.
Also, correct. I meant aluminum, and copper. I have used many combinations, and it has been a while, so my memory is kinda foggy. Copper corrodes fast, though. Aluminum works great, but after some time, it may need replacing. Salt is ok. If you plan on using salt, i would suggest using Distilled water, with some salt in it. It works very well! Sorry for the mix ups! It has been about 2 years since i played with this stuff.
Old 14th August 2006, 03:15 AM   (permalink)
Experienced Member
Still a miss. Heavy water is H2O made with the deuterium isotope of hydrogen.
H3O is the hydronium ion that mades acid acid.
Old 14th August 2006, 07:02 PM   (permalink)
Experienced Member
I bow down to you, God.
Old 14th August 2006, 07:11 PM   (permalink)
Experienced Member
Also known as D2O.
JB
Old 15th August 2006, 01:33 PM   (permalink)
Aphromann is on a distinguished road
Would it not be easier to obtain the licenses to fill a tank of hydrogen and a tank of oxygen and created water? The energy generated is explosive and only leaves a drop of dew, very fun for recreational explosions, especialy if the catalyst is in a balloon.
Aphromann is offline   Reply With Quote
Old 15th August 2006, 10:29 PM   (permalink)
Experienced Member
Is there a Limit On how much current the system will consume? How can I increase current going to the system? It seems like it Only Consumes around 1-2Amps. My PSU however, can supply 8 Amps if needed (Im using a computer PSU).
Ive also heard I can increase voltage, I tired 5V and It went slow (too slow for me). When I bumped it up to 12V it went A lot faster. I have a 44V Transformer, Can I just use a Rectifier with it (To turn AC to DC), instead of creating a Regulator (with caps and such)?
Old 15th August 2006, 10:50 PM   (permalink)
Experienced Member
Go for it. It shouldn't matter, it doesn't need to be regulated. The more power(with-in reason), the faster it will go. Don't get too high, or bad things may happen. I used to use 12vdc, but that got boring, so i started using 18vdc.
Old 16th August 2006, 12:08 AM   (permalink)
Experienced Member
Bad things? What kind of bad things?
