Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 18th March 2007, 12:44 PM   (permalink)
Experienced Member
Oxygen doesn't burn in oxygen, it's the other way round, hydrogen burns in oxygen.
Pure water is an insulator, in order for it to become a conducto it needs to be ionised and this is normally is done by adding an ionic compound. Unfortunatey the ionic compound normally decomposes to give chemicals other than just oxygen and hydorgen, for example, common salt gives toxic chlorine gase and sodium hydroxide. I don't know if there are any ionic compounds that don't decompose or reform in the mixture so no other chemicals are produced.
Old 18th March 2007, 01:37 PM   (permalink)
Experienced Member
Thunderchild is just really niceThunderchild is just really niceThunderchild is just really nice
Send a message via MSN to Thunderchild Send a message via Yahoo to Thunderchild
ah right thanks I guessed it was probably the hydrogen tube we used as a "candle" but the teacher did it all not the sort of thing he was going to let us mess with
my site:www.simons-photography.com
http://rushdenrotaract.org.uk
see also
http://www.bigstockphoto.com/account...fid=m2URATYch5
http://www.redbubble.com/people/simonsphotography
Thunderchild is offline   Reply With Quote
Old 21st March 2007, 09:36 PM   (permalink)
Experienced Member
CheapSlider is on a distinguished road
I found that producing hydrogen by a chemical method was quicker than electrolysis
Chemical
Hydrogen was made from Hydrochloric acid + Zinc.
(Hydro and Sulphuric acids can be easily obtained in the UK. Zinc is used on roofs)
Oxygen could be made from Hydrogen Peroxide and Manganese Dioxide (removed from old zinc carbon batteries and washing out the ammonium and zinc chlorides)
Electrolysis
For electrodes I used carbon rods (removed from old zinc carbon batteries) placed in a plastic bucket.
Gases were collected by the “displacement of water in an inverted vessel” method. I put a funnel into 2 plastic soft drink bottles and then inverted these bottles over each set of carbon electrodes in the bucket. (The bottles were full of water). A small drop of acid was added to the water in the bucket
A cylinder stat was attached to the side of the bucket. The AC supply was connected in series through the stat and a current limiter to a bridge rectifier which provided the DC for the carbon rod electrodes.
This was all done outside under a tarp – NEVER try this in an unventilated area.
-The rate of gas production was very disappointing
Inflating Ballooons
I epoxied 2 tubes into a bottle stopper. This stopper was put on the bottle which had the collected gas. The balloon was attached to 1 of the tubes from the stopper, the other tube was connected to a water tap. The pressure from the water tap would fill the balloon with the gas from the bottle.
WARNING.
KEEP OUT OF SUNLIGHT
If you are mixing hydrogen and oxygen then be aware that it can explode if exposed to sunlight or even a bright light.
STATIC
If you’re using balloons be careful about producing static from rubbing the balloons
DON’T STORE GASES in balloons or soft drink bottles – they are both porous to gas.
CheapSlider is offline   Reply With Quote
Old 22nd March 2007, 02:49 AM   (permalink)
Experienced Member
Sceadwian is a glorious beacon of lightSceadwian is a glorious beacon of lightSceadwian is a glorious beacon of lightSceadwian is a glorious beacon of light
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
Has anyone mentioned that purchasing hydrogen gas for experimental purposes is as simple as going to a local welding supply shop with an aproved canister?
Curiosity killed the cat; That's why they have nine lives.
Sceadwian is online now   Reply With Quote
Old 22nd March 2007, 12:14 PM   (permalink)
Experienced Member
Originally Posted by CheapSlider
WARNING.
I would assume that's caused by ionising radiation, all that's needed is some UV photons to come in and srtirp a few electrons off a couple of oxygen and hydrogen molecules and bang! I wonder if and x and gamma rays in the back ground radiation could have the same effect. Putting a balloon filled with hydrogen and oxygen next to a smoke alarm is probably not a bright idea.
There again storing mixtures of hydrogen and oxygen is pretty stupid anyway.
I suppose hydrogen molecules are smaller than oxygen molecules so theres more chance of them slipping though the seals.
Old 10th April 2007, 02:39 AM   (permalink)
Souper man
Guest
Originally Posted by Marks256
Yes, i am sorry, H3O is heavy water. Yes, H2O2 Is correct, so you will get equal amounts of each.
Also, correct. I meant aluminum, and copper. I have used many combinations, and it has been a while, so my memory is kinda foggy. Copper corrodes fast, though. Aluminum works great, but after some time, it may need replacing. Salt is ok. If you plan on using salt, i would suggest using Distilled water, with some salt in it. It works very well! Sorry for the mix ups! It has been about 2 years since i played with this stuff.
Use zinc anode and copper cathode, they work wonders!
Old 20th June 2007, 06:04 PM   (permalink)
dragonxwas is on a distinguished road
Hey buy some distilled water from gas station add few drops of h2so4 in it an use a 1A 12v transformer use the rectifier with it ..rectifier consisting of 4 diodes and an capacitor is preferred ....use rolled aluminium foil as electrodes as this will increase surface area and split water fast
dragonxwas is offline   Reply With Quote
Old 21st June 2007, 01:50 AM   (permalink)
Souper man
Guest
I bought a inverter transformer with input of 3VDC and output of 200VAC, and Im going to try out some electrolsys, but I was wondering how big of an explosion it would make! (water wont explode like this, i think...)
Old 21st June 2007, 06:11 AM   (permalink)
Experienced Member
TheVictim has a spectacular aura about
Send a message via AIM to TheVictim
Storing mixtures of hydrogen and oxygen in bottles is dangerous? Uh oh, I filed a bottle with H2O and put it in the fridge, I hope it is going to be OK in the morning...
TheVictim is offline   Reply With Quote
Old 21st June 2007, 09:23 PM   (permalink)
Souper man
Guest
Be careful, you could wake up to...
COLD WATER!!!
Old 22nd June 2007, 03:40 AM   (permalink)
beachracer is on a distinguished road
Does anyone know the correct (or optimal) ratio when mixing Potassium Hydroxide (I am using pellets) to water for an electrolytic solution?
Thanks in advance.
br
beachracer is offline   Reply With Quote
Old 22nd June 2007, 03:47 AM   (permalink)
Experienced Member
mneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of light
Send a message via AIM to mneary
Until the Ph is 7.0.
mneary is online now   Reply With Quote
Old 22nd June 2007, 04:02 PM   (permalink)
Experienced Member
Experimentally that can be determined by first making a saturated solution from the pellets, then adding it incrementally to water with electrodes in it connected to an ohmmeter. When your resistance no longer drops after adding more lye, you'll have your concentration.
Old 30th August 2007, 05:18 AM   (permalink)
firewater is on a distinguished road
This guy John Aarons has already posted 181 videos on Youtube with 98% of them on producing hydrogen through electrolysis http://www.youtube.com/user/johnaarons
His web site with parts and complete systems for sale:
http://hydrogentap.com/hydrogentap_001.htm
Other sites for parts:
http://stores.homestead.com/hydrogen...StoreFront.bok
A huge source for information on Hydrogen production through a variety of methods with forums.
http://my.opera.com/H2earth/blog/cybrarium
Some general guidelines:
  1. Use distilled water to give you a base line to start experimenting and other wise the minerals in tap water will eventually turn the water into a mud like goop.
  2. Use stainless steel electrodes either flat or tube.
  3. Use just a pinch of Lye,the amount depends on many things,volts,amps,amount of water,total surface area of the electrodes and their spacing.
  4. Too high amps will create run-away heating.
  5. Use outdoors or VERY well ventilitated areas for SHORT durations.There are ways to prevent explosions, bubblers, water filled U tubes and silicate sand supported by screens and fiberglass cloth.http://67.76.235.52/cre.asp Also google "hollow-fiber membrane gas separation"
firewater is offline   Reply With Quote
