Experienced Member
I said bad things MAY happen. I don't know. Possible overheating, shorting out. You should be pretty safe at about 44volts. However, i wouldn't tempt fate with anything higher.
Experienced Member
Experienced Member
Hmm, ok, try it. It is worth a shot. I have a question, if you run 120vac into a rectifier, will you get 120vdc out, or 60vdc out?
Experienced Member
Electrolysis requires only 1.2v. If the resistance of your system- only salt water electrolyte and stainless electrodes- the current will be low. Basically I=(Vin-1.2v)/R. The rest is dissipated as heat. If you're using more than 5v, there's a whole lot of heat being generated!
I thought what I'd do was I'd pretend I was one of those deaf-mutes. |
Experienced Member
Experienced Member
What is RMS?
Experienced Member
Experienced Member
Ok, i don't get it, so i am just going to leave it alone. Ahh. Ahh, ok, i must know! How do you find the RMS voltage?
Experienced Member
Pass it through a regulator and you can end up with anything from 1V to 16.9V (if you have a low voltage drop out regulator- meaning the regulator does drop alot of voltage- for example, a Diode drops .7V.) So If you have Peak voltage (which you rarely have, but it comes in handy when your talking power) and you want RMS, Divide Peak Voltage by 1.414 or Multiply by .707 Just a note, Power, Voltage and current can all be applied to this. For example, your speaker may put out 50W RMS, that would be 70.7W Peak. As Ive said before, .707 and 1.414 are the Average Voltage over a period of time. |
Experienced Member
Oh, ok, i see. Thanks.
Super Moderator
True RMS meters are available, but are much more expensive. Also, old moving iron meters read RMS - due to the different way they work. RMS is really VERY simple, it's the AC voltage that gives the same heating effect as the same DC voltage. So 120V RMS to your electric heater will make it exactly the same heat as 120V DC. |
Experienced Member
Few questions about the gases collected...
First, how would one fill a balloon with the combined gases. Electrolysis seperates, but doesn't build any pressure, atleast not enough to inflate a balloon. Second, once the balloon is filled, how bouyent will it be? I know that hydrogen is lighter than helium, and will float well, but oxygen is heavier. So how much weight will this balloon lift? Enough for a timer, battery, and ignition circuit? |
Experienced Member
Trying to recreate the hindenburg I see. |
Experienced Member
Experienced Member
No no no. See, the hydrogen and the oxygen will be produced at two separate locations. It is 100% possible to harvest just hydrogen.
This is what you do; 1. Take a glass jar (yes it MUST be glass, so you can see all the cool things happening), 2. Find a lid for your glass jar. 3. Drill two holes in the top, both about .5" in diameter. 4. Stick a pipe trough each of the holes(make sure they fit sort of loose, but not too loose!) 5. Run a wire down the side of the pipe, through the hole, and into the jar. 6. Stick a conductive plate on the end of the wire. 7. Seal the hole with some type of putty.(make sure it is REALLY sealed tight!) 8. Put the lid on the jar(you know, the lid with the holes, the pipe, and the wire.) 9. Fill the jar with water. Yes, through one of the pipes, and make sure the water is also all the way up both pipes. 10. Put each balloon on each pipe. MAKE SURE NO AIR GETS INTO THE DEVICE! Air will wreck dilute the elements! 11. Check for leaks, and deal with them. 12. Apply power to each of the wires. 13. Let it run for a while, or until each balloon is to the desired limit. 14. CARFULLY take each balloon off the machine, and seal them. WITHOUT letting any air in! Explanation: The water in the balloons will act as a seal for the hydrogen and oxygen. It also acts as a pressurizer. So, when the hydrogen and oxygen are made, then it will fill the balloons. If you would like, i will draw a few diagrams for you. |
