Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 5th July 2006, 09:54 PM   (permalink)
Default Wind Powered Battery Charger
Making the best use of a light breeze that may not provide enough energy to charge a lead acid accumilator by diverting the available charge to low voltage Ni-Cad's. Plus , it also can limit the generator RPM should the need arise.
It may seem like a good idea at the time , but never stir your cold coffee with a soldering iron.
The Mad Professor is offline   Reply With Quote
Old 5th July 2006, 11:03 PM   (permalink)
Paul Obrien
Sure, as it says voltage is proportional to wind speed and most light breezes won't be able to charge at a high current rate. Why not use the overload resistance to heat water as well, water is great for thermal transfer.
Old 6th July 2006, 05:44 PM   (permalink)
Agreed , rather than dump the heat to atmosphere using it to heat a water (or oil?) reservoir would make sense.
Old 6th July 2006, 09:22 PM   (permalink)
How about using a switching regulator with a transformer that could output 13.8V with the current limited to 1A from a wide input voltage range, like 5V to 20V?
Screen name: Aloone_Jonez
Old 24th July 2006, 12:32 AM   (permalink)
A centrifugal device and springs to change the blade angle at different wind speeds I found was the best solution, you can with a bit of cunning increase the blade area at low wind speeds.
oldtimer is offline   Reply With Quote
Old 18th October 2006, 06:01 PM   (permalink)
nye
forgive me for my ignorance..but im sorta a newbie..the LM334 is a constant current source right??when buying thecomponent, wht should ask for??jus mention 'LM334"???are all components cheap in this circuit??
\"electricity is a good slave, but a bad master\"
nye is offline   Reply With Quote
Old 18th October 2006, 06:39 PM   (permalink)
Paul Obrien
yes it is and in the circuit it acts as a current limiter and diode for the NiCad batteries, since the LM334 is limited to 10mA output there would be a better way to recharge 4 nicads but the circuit doesn't need much power so I suppose I'd let that one slide through
Old 12th March 2008, 03:54 AM   (permalink)
If power is 100V to 200V : Three Phase Delta : Than how do you charge : 24V 0 40 amps batteries using this technology
rajoverseas is offline   Reply With Quote
Old 12th March 2008, 06:06 AM   (permalink)
if you have 3 phase 100 a 200 volt i assume that you use a normal 3 phase electro motor as generator then you can step it down with a transformer to the prefered voltage (it's AC) and then make the charger for you batteries
this charger will be different as the circuit that is posted in this tread
rjvh is online now   Reply With Quote
