| | #1 (permalink) |
| Experienced Member Join Date: Mar 2006 Location: Newent England
| Making the best use of a light breeze that may not provide enough energy to charge a lead acid accumilator by diverting the available charge to low voltage Ni-Cad's. Plus , it also can limit the generator RPM should the need arise.
__________________ It may seem like a good idea at the time , but never stir your cold coffee with a soldering iron. |
| | #3 (permalink) |
| Agreed , rather than dump the heat to atmosphere using it to heat a water (or oil?) reservoir would make sense.
| | #5 (permalink) |
| Experienced Member Join Date: Jul 2006 Location: Florida (english ex pat)
| A centrifugal device and springs to change the blade angle at different wind speeds I found was the best solution, you can with a bit of cunning increase the blade area at low wind speeds. |
| | #6 (permalink) |
| Experienced Member Join Date: Jan 2004 Location: Sri Lanka & Australia
| forgive me for my ignorance..but im sorta a newbie..the LM334 is a constant current source right??when buying thecomponent, wht should ask for??jus mention 'LM334"???are all components cheap in this circuit??
__________________ \"electricity is a good slave, but a bad master\" |
| | #7 (permalink) |
| Guest
Posts: n/a
| yes it is and in the circuit it acts as a current limiter and diode for the NiCad batteries, since the LM334 is limited to 10mA output there would be a better way to recharge 4 nicads but the circuit doesn't need much power so I suppose I'd let that one slide through |
| | #9 (permalink) |
| Experienced Member Join Date: Dec 2007 Location: cambodia
| if you have 3 phase 100 a 200 volt i assume that you use a normal 3 phase electro motor as generator then you can step it down with a transformer to the prefered voltage (it's AC) and then make the charger for you batteries this charger will be different as the circuit that is posted in this tread |
