Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Alternative Energy
Alternative Energy Discussion relating to the design and implementation of alternate energies.
Old 26th October 2005, 02:33 PM   (permalink)
Like a guy on another electronics chat forum who wanted to use a computer fan as a generator to power many LEDs and charge Ni-MH cells on his bicycle.
The fan actually powered a single LED very dimly when he was going as fast as he could go downhill. It would take weeks to charge his little battery.
I suggested reversing the connections so the little fan was powered from his battery and it could propel him along. Its thrust was about 10 grams. :lol:
Old 26th October 2005, 03:18 PM   (permalink)
Originally Posted by williB
no i havnt tried a dc motor/generator ..
i'm gonna keep plugging away , i wouldnt say all the results so far are poor..
with the single phase generator i was getting a lot more voltage but the coils were bigger .
i've ordered some 20 gage wire ( .032 '' ) which should give better results for a three phase genny..
It's not voltage that's important, it's power!, all the results you've mentioned so far are only very low power. Remember the little DC dynamo's you get on push bikes?, they produce enough for the lights whilst taking very little effort from the rider.
I'm very impressed with the effort you're putting into it, but the results are rather disappointing.
Old 29th October 2005, 02:28 AM   (permalink)
Whew !!
almost done !!
it still needs a little tweaking, like adjusting the air gaps .
i ran out of brass screws , and had to use stainless.
and i still have to solder some of the connections.
this is my first 18 coil 24 magnet three phase generator !
the last phase was the easiest to attach because there was only one spot left to put the coils :lol:
williB is offline   Reply With Quote
Old 29th October 2005, 06:02 AM   (permalink)
Big mess of wires. :lol:
You have to triple check here to make shure evrything is wired up right.
The easyest mistake to make is conecting the coil the worng way round becose bouth wires are identical.
Il give you shocking experience.
Someone Electro is offline   Reply With Quote
Old 29th October 2005, 05:51 PM   (permalink)
Well the results are in..
I was close when i said the open circuit voltage would be 11v it is actually 12.5 to 13.05 Volts depending on which meter i use ..
the measured resistance of each phase is 0.5 Ohms and the line to line resistance is 1.0 ohms..
all measurements are DC and are recitfied with six diodes, and all current measurements are taken with the meter on the 10A scale..
into a 1 ohm resistor at one speed i got 3.9V @ 4.05 A = 15.75 W
at a faster speed also into a 1 ohm resistor i got 4.16V @ 4.28A = 17.8 W
and with the output going directly into the meter on the 10A scale 6.67A @ 1.97V = 13.14W
not too shabby for (24) 1/2 '' magnets and some wire ..
I cant wait till the 20awg wire gets here..
Old 29th October 2005, 08:07 PM   (permalink)
Watts (what's) the efficiency? A couple of hundred watts of work to get 15W out?
Old 30th October 2005, 03:15 AM   (permalink)
please dont post in my threads anymore, thanks
Old 30th October 2005, 03:45 AM   (permalink)
I've found a new source for Neo-Magnets, but havnt tried them yet..
http://www.magnetsrc.com/neo_NdFeB_m...isc_magnet.htm
below is a new generator designed with 7/8'' dia x .5'' magnets, it should give , an open circuit , output of at least 32 V with 20 AWG wire , current estimates are unknown at this point .. :lol:
oh the coils are 1.75'' dia., twice the magnet dia..
Old 30th October 2005, 07:53 AM   (permalink)
It's a VERY valid question, so far your designs appear to be very low efficiency, and you don't seem to be testing how well they work?.
Old 30th October 2005, 02:17 PM   (permalink)
How would you test them ?
ps my apologies audioguru
Old 30th October 2005, 03:25 PM   (permalink)
How about 'the perpetual motion way'?.
Use a DC motor to spin your generator, monitor the current to the DC motor and the voltage across the motor - simple VxI gives you the input power to the drive motor.
Apply varying resistive loads to the output of the generator, again monitoring both current and voltage (FOUR multi-meters would be useful here!), simple VxI gives you the output power. You should be able to find a load value that gives the most power (largest VxI). It will give you the opportunity to post some more nice diagrams, this time of the load versus power graphs.
By comparing the input power and the output power, and at different load levels and speeds, you can get an idea of how efficient it is. Using different speeds might be informative as well?.
Obviously, this introduces the unknown efficiency of the drive motor, but you can ignore that as you're not wanting absolute values, just a comparative test of which might be better.
As I mentioned previously, try a commercial dynamo or alternator, or a DC motor backwards, and see how your generators compare - if you're not beating them it's rather a pointless exercise? - but VERY educational!.
Old 30th October 2005, 07:01 PM   (permalink)
Nigel , i think that sounds like a lot of work .. and to what end?? i know it works.. and works well..!!
Old 30th October 2005, 07:05 PM   (permalink)
I thought you were trying to make subjective tests?, but perhaps you're not bothered about how well it works? - as long as it works well enough!.
Old 30th October 2005, 09:05 PM   (permalink)
Willie,
At the risk of having missed the point somewhere here, there are two things which seem to be wrong with your generator.
The rather odd ratio of magnets and coils, I would have expected a ratio of 1:1 or 2:1, but I am not an expert on 3 phase genrators.
What are the coils mounted on? it looks like a wooden board, and they are held on with brass or stainless steel screws.
What are the magnets mounted on? I cannot tell.
You have a serious problem here, there is no magnetic circuit!
Have a look at (say) a simple permanent magnet motor. There will be two iron poles from the magnet. The poles are very close to the rotor, a very small air gap, and the rotor is its self made of iron.
Lots of magnetic material to make a magnetic circuit.
What is in your magnetic circuit? several inches of air and wood. Not good.
JimB is offline   Reply With Quote
Old 30th October 2005, 09:36 PM   (permalink)
Hiya Willi,
As Jim stated above, it looks like you've mounted everything on plywood and not steel. All the stators I've looked at are suspended in fibreglass and held stationary. The magnets are mounted onto a disc of 3/8" minimun as this lets the flux generatored from the magnets to flow. This has been talked about heaps on the otherpower forum and atleast I find by reading otherpower posts I can avoid their mistakes and make up a working unit in 1 go.
Cheers Bryan
bryan1 is offline   Reply With Quote
