| 8051/8951 A specify forum for the Intel 8051/8951 single chip microcontroller. |
hi all...i m v.new to microcontrollers...i want to make a system in which a 8051 microcontroller upon an interrupt will 1) direct the pc via a serial port(rs-232 interface using max 232 ic) to instruct a webcam to capture an image. 2) The webcam will be connected to the pc via usb port. i need basic help here.... 1)in coding in assembly language...and 2)other valuable knowledge relating to serial and usb ports..... ive only known microcontrollers for a month and this help is going to be extremely essential for my semester project.......i need help urgently....thanking u in anticipation.... | |
hi ...i m v.new to microcontrollers...i want to make a system in which a 8051 microcontroller upon an interrupt will 1) direct the pc via a serial port(rs-232 interface using max 232 ic) to instruct a webcam to capture an image. 2) The webcam will be connected to the pc via usb port. i need basic help here.... 1)in coding in assembly language...and 2)other valuable knowledge relating to serial and usb ports..... ive only known microcontrollers for a month and this help is going to be extremely essential for my semester project.......i need help urgently....thanking u in anticipation.... DONT SPAM MESSAGES TO PEOPLE! YOU SHOULD HAVE LEARNED THIS!
__________________ IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S | |
| | #3 | |
So all you have to do is make a vb program that will listen to the com port and when a specific command is read send the keys needed to work the other program. You can always just make a program to control the webcam itself but requires way more experience.
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | ||
Its easy to implement a computer controlled automation system if you have know how to communicate between PC & the uC. See the link it has the same uC type & has some VB tutorials. Free 8051 Microcontroller projects - Visual Basic for 8051 Microcontrollers | |
| 8051, interfacing, microcontroller, webcam |
| Webcam controlling using microcontroller | HiteshDR | Electronic Projects Design/Ideas/Reviews | 0 | 1st November 2007 12:43 PM |
| help in interfacing with 8051 | net_tej | 8051/8951 | 4 | 22nd September 2006 05:38 PM |
| interfacing a webcam or a cellular phone cam with uc | razielworthy | Electronic Projects Design/Ideas/Reviews | 0 | 27th March 2006 10:24 PM |
| webcam and microcontroller | beginner2 | Electronic Projects Design/Ideas/Reviews | 15 | 4th September 2005 08:47 PM |
| interfacing 8051 with usb | kantak | Electronic Projects Design/Ideas/Reviews | 0 | 21st March 2005 05:58 AM |
