| 8051/8951 A specify forum for the Intel 8051/8951 single chip microcontroller. |
Hi im using 89S52 UART With max232 , the transmitter to pc works fine to hyber terminal but the reciever doesnt work , and the code works fine on the keil UART simulator ! i dont know why the reciever doesnt work , is there a setup for hyber terminal to let the reciever work ? thanks | |
Try setting handshaking to NONE in "hyber terminal" if you haven't already.
__________________ Inside every little problem, is a big problem trying to get out. | |
thanks for the reply what's handshaking i didnt put it to NONE in hyperterminal .. how to do it so do u think the problem isnt in the hardware ? | |
It is one thing of many that could be wrong but the easiest to fix. ![]() Look here:
the Tx to pc is working but from pc to the micro it doesnt is this is problem ? thanks again | |
| | #6 |
i set the handshaking to none and still the hyber doesnt send charachters :S and the micro doesnt recieve... is there a test to make sure the circuits are working ? | |
| | #7 |
You can check that the pins on the MAX232 have the following voltages: Pin 16 = +5V Pin 2 = +9V Pin 6 = -9V Pin 15 = 0V (ground reference for above measurements) Without a diagram it is hard to tell which input on the MAX232 your are using, but when the PC sends data to the PIC you should get activity on either pins 8&9 or pins 12&13 of the MAX232.
| 8051, problem, serial, uart |
| hyperterminal communication w/ 8051 | spyghost | 8051/8951 | 8 | 22nd May 2008 11:54 AM |
| Big thermocouple ADC problem | Oznog | General Electronics Chat | 9 | 4th May 2004 09:42 PM |
| pic16f877 serial recieve acting screwy | masconejos | Micro Controllers | 6 | 9th April 2004 11:09 AM |
| 8051 microcontroller reading data from serial port | godatguitar | 8051/8951 | 11 | 17th February 2004 09:04 PM |
| I NEED CODE FOR 8051 SERIAl comm..PLSSS HELP | kumar_3k | 8051/8951 | 2 | 3rd January 2004 03:30 AM |
