Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Micro Controllers > 8051/8951
8051/8951 A specify forum for the Intel 8051/8951 single chip microcontroller.
Old 5th March 2007, 05:09 PM   #1
Default interfacing dc motor with 8051
hi
Can any body help me??
i need circuit description for interfacing a dc motor with 8051 uc!
abbas1707 is offline
Old 7th March 2007, 06:18 AM   #2
Default what u wana....
hi aabbas how r u
what u actually wana do to a dc motor by interfacing with microcontroller
thenewton is offline
Old 7th March 2007, 02:05 PM   #3
hi abbas,
What type of motor do you want to interface?
Example: 12Vdc requiring say, 100mA ?
Do you want to control its speed or just stop and start it?
EricG
ericgibbs is offline
Old 27th October 2008, 07:43 AM   #4
[QUOTE=ericgibbs;201365],
i want dc motor controlled through 8051.
Do you hav a prj to control its speed or just stop and start it?
Muhammad Saeed Anwer is offline
Old 27th October 2008, 09:10 AM   #5
hey!! you have the same name as me where are you located?
how do you intend to control it?using pwm i guess or you just need to turn it on and off?
OR
this is a hardware question?
I just cant come up with a good one!
silvarblade is offline
Old 27th October 2008, 10:29 AM   #6
[QUOTE=Muhammad Saeed Anwer;658932]
You should decide on the motor control you require .
Start/Stop is a simple medium power drive transistor, the transistor base being switched by a 8051 output, via a base resistor.
For Start/Stop and simple reversing a 'H-bridge' is normally used, controlled by ON/OFF Fwd/Rev signals from the 8051.
For the above and SPEED control a 'H-bridge' driven by the 8051 using PWM control signals..
Which is it.?
Old 27th October 2008, 10:51 AM   #7
Hi Eric,
that is correct, I'd like just to add that if bidirectional control is not needed, a MOSFET transistor can be used. There are "logic-level" N-channel MOSFETs (for example RFP3055LE) that can be controlled directly by a logic output. Simple and better solution than a BJT.
Petr
petrv is offline
Old 28th October 2008, 12:13 AM   #8
Not to hijack this thread, however I have a question that I believe is in line with this topic so I thought I'd ask it here instead of starting a new thread.
What would you recommend for controlling the speed of a higher current DC motor? The motor is a 100W MY68 model (24V and rated for 6A, 2300 rpm) and I would like to be able to reverse the direction of rotation.
I am thinking about using the PWM module on a PIC18F4550 (or any PIC with PWM capabilities for that matter) and a few power Mosfets in an H-bridge configuration. The problem is I believe sizing components carefully so the system is reliable long term and using adequate protection so that I won't have any components die because of excessive current/heat.
WizzBall is offline
Old 28th October 2008, 05:50 AM   #9
Lots of examples:
Motor, Coil, Relay, and LED Drivers
fsmyth is offline
Old 29th October 2008, 08:53 AM   #10
hi silvarblade!
thanks 4 guiding. i m located at Karachi, Pakistan. what about u?
i need code of this prj but when u insert rpm motor will rotate at this speed? i now about its diagram but problem of its code of controlling the duty cycle which is responsible for increasing the speed of motor.
plz help me.
again thanks to all 4 guiding.
Old 3rd February 2009, 02:47 PM   #11
hi, cud u pls send the ckt u used to interface the motor with the microcontroller used, i dont know, how to connect the motor with the 8051, pls do it soon, last time i connected, something went drastically wrong, its my most urgent request, pls help...
siva_elven is offline
Old 31st August 2009, 07:42 PM   #12
Originally Posted by abbas1707 View Post
hi
I would suggest that don't go for analog design.
Use a motor driver IC. Say L293D
Give microcontroller output to motor driver and then give output of motor driver to DC motor.
Please let me know if you need any more help.
Thanks,
Rushikesh
www.projectsof8051.com
rushi53 is offline
Old 8th September 2009, 02:54 AM   #13
Also read the datasheets of l293 carefully..
shree-electronics.com - Abrreviations and microcontroller related stuff.
srikanthsamaga is offline
8051, interfacing, motor
ADC 0809 interfacing with 8051 infinity 8051/8951 5 15th October 2009 07:03 AM
interfacing 8051 to a gsm phone simrantogether 8051/8951 7 7th August 2008 07:50 PM
need urgent help on interfacing USB bluetoothdongle wit 8051 prasaddinkar 8051/8951 6 24th January 2006 12:46 AM
interfacing DS-12887 and PCF8591 with 8051 useant Electronic Projects Design/Ideas/Reviews 0 28th August 2005 04:01 AM
interfacing 16*16 matrix display with 8051 pmphilip 8051/8951 0 1st February 2005 04:47 AM
