Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Micro Controllers > 8051/8951
8051/8951 A specify forum for the Intel 8051/8951 single chip microcontroller.
Old 23rd April 2005, 07:33 PM   #1
Default ADC 0809 interfacing with 8051
I have to interface AdC 0809 to 8051 in my project. Can anyone give me the programming code for ADC interfacing to 8051?
infinity is offline
Old 24th April 2005, 03:38 PM   #2
First make clear, how many AD channels you want. As ADC0808/9 is having 8 channels, meaning you can input 8 different analog inputs and select any one of them at any time with the help of onchip mux. If you want to scan a single analog input, then use ADC0801.
Everything is given in the datasheet regarding connecting ADC with uC etc.
Anyway you simply ground the chip select pin (CS) of ADC, connect the read(start) pin and write pin to uC. Connect the INTR pin of ADC to INT1 pin of uC (8051) and the data of ADC to any port of your interrest (Precaution with P0 is you need to give pull ups).
This much is enough to interface ADC0801. If using ADC0808/9, you need to give select lines from uC to ADC.
Program sequence will be.
apply active low pulse at write pin of ADC
wait till interrupt comes.
write ISR for hardware interrupt 1 as follows.
apply active low pulse at read pin of ADC
read the port.
Lastly, you will get everything regarding ADC0801 here.
http://www.google.co.in/search?sourc...D:en&q=ADC0801
sarang1_in is offline
Old 25th April 2005, 07:58 PM   #3
This ADC is designed to be memory mapped. You can connect it to the external memory bus on your 8051. The MOVX instruction can be used to read and write to the ADC. Just connect RD,WR and DB0-7 to the coresponding 8051 bus pins. You can pick an Address pin (AD8-15) and connect it to CS. When you do a MOVX to a memory location that sets that address pin high the write or read will go to the ADC.
Your code then becomes one instruction: MOVX A, @DPTR to read the ADC through the bus.
bmcculla is offline
Old 3rd May 2005, 09:03 PM   #4
Default program for 0809
clr p3.6
setb p3.6
clr p3.6
mov p0,10100000b
setb p3.7
clr p3.7
setb p3.7
setb p1.7
clr p1.7
setb p1.6
herr: jb p1.6,herr
setb p3.6
mov p2,#11111111b
mov r5,p2
;------------------------------ to 0809
p3.7 to ale ((adress lach eneble)
p3.6 to oe (out eneble)
p1.7 to start :
idea:
p1.6 to eoc
p0 canect to 0809 adress (abc) :idea:
saman_bk is offline
Old 13th October 2009, 10:56 AM   #5
give me the ckt of the interfacing of microcontroller and analog to digital converter
jatin_patel_1489 is offline
Old 15th October 2009, 07:03 AM   #6
Hope you have find the solution,
if not then my code might help you
; Pin Definations
adc_data_bus    equ     90h             ; Port 0
adc_add_a       equ     b4h             ; P3.4
adc_add_b       equ     b3h             ; P3.3
adc_ale_soc     equ     b5h             ; P3.5
adc_eoc         equ     b6h             ; P3.6
adc_oe          equ     b7h             ; P3.7
; Main Program starts from here
adctemp:        clr adc_add_a           ; Channel 0 is ie Temp is selected
                clr adc_add_b           ;Add b = 0, Add a = 0
                nop
                setb adc_ale_soc        ;ale and soc is made high
                nop
                nop
                nop
                nop
                clr adc_ale_soc            ;ale and soc is made low
                jb adc_eoc,$               ;check for eoc
                jnb adc_eoc,$             ;check for eoc
                setb adc_oe                ;if eoc high,make oe high
                nop
                nop
                nop
                mov a,adc_data_bus     ;Read port0 data to accumulator
                mov 40h,a              ;Copy this data in 40h for furher processing
                clr adc_oe                ;make oe low
                ret
Program ENDS here
Please let me know if you need any more help
Thanks,
Rushikesh
www.projectsof8051.com
Last edited by rushi53; 15th October 2009 at 07:07 AM. Reason: ALE and SOC pins of ADC should be shorted
rushi53 is offline
0809, 8051, adc, interfacing
